Can i hit 500awhp?
Old Oct 5, 2008 | 08:58 AM
paintballproam's Avatar
Originally Posted by mudduck
wait, how much power are you making with your current setup that trapped 124.7mph?
I havnt dynod it
but at 3300lbs i did 11.5 @ 124.7mph. Dyno sym estimated me at 420hp
Old Oct 5, 2008 | 09:03 AM
4g63smokinall4s's Avatar
on a dyno jet.. possibly.. no chance in hell tho on a mustang dyno..
Old Oct 5, 2008 | 09:05 AM
Well im not trying for a dyno jet. I want a real 500whp evo.
I dont want people to be like, oh you only made that power on a dyno jet. or something like that
Old Oct 5, 2008 | 09:08 AM
Good idea
with the meth on there you should put down some really good numbers.. like u stated earlier if you do go 35r you will make hella more up top and def be alot closer to 500 then with the 50 trim
Old Oct 5, 2008 | 04:48 PM
EMonz57's Avatar
Correct me if I am wrong here but I belive the 35r can be a direct swap out for the 50trim you have. You may want to find out with turbotrix but that would mean only needing the turbo. Then you could sell your turbo all in all easy transaction without spending a ton
Old Oct 5, 2008 | 06:36 PM
Oh really? I could swap it out for a HTA?
Old Oct 5, 2008 | 06:39 PM
staatz's Avatar
No. When I had the TTR 50trim their 02 housing flange was completely different to the flange off the 35r. I guess it was an old style flange but either way I swapped the 02 housings to the 35 and the car was way more responsive between shifts and I made 473whp at 23psi on pump and meth. I could not boost any higher was I was having ignition problems from my coils.
Old Oct 5, 2008 | 06:45 PM
You made that power on the 50 or the 35?
Old Oct 5, 2008 | 07:17 PM
huevosrancheros's Avatar
No
Old Oct 6, 2008 | 06:11 AM
any more input?
Old Oct 6, 2008 | 06:40 AM
supersal's Avatar
any more input?
You can upgrade your 50Trim Turbo with bigger wheels...
A 60-1 Compressor wheel with a AR70 T04S Cover can flow 61lbs
So maybe thats another option.
Is seems lag isnt an issue for you so you don't mind going with a GT35R
other option might be a HTA3076R it can flow 57lbs so can make 500whp more easily than a 50Trim.
Old Oct 6, 2008 | 05:58 PM
Well i dont think the lag in the 50 trim is bad at all
what do the 35r hta or the turbos you listed spool up at?
Old Oct 6, 2008 | 07:28 PM
Red_Evolution's Avatar
i believe a regular 35r hits full spool around 4500-4700 rpms... and an hta 35r hits a couple hundred rmps earlier.... probably around 4100-4400
Old Oct 6, 2008 | 07:31 PM
Oh well 4100-4400 wouldnt be THAT much more that the 50 trim.
So is there anyway to upgrade to a hta 35r without having to get the entire kit? I emailed turbo trix and ams asking them, but id like to see if anyone on here knows
Old Oct 7, 2008 | 01:44 AM
supersal's Avatar
Turbotrix will need to confirm but the simple solution I believe would be to order your 35R with the same exhaust housing your 50Trim has...
So if you have a 5 bolt ford style T3 Housing then you need to order a GT35R with this very same exhaust housing - I think ATP does offer this option.
