oil light flickering what's it mean?
I had my oil changed on Thursday and on Sat I noticed my light would flash only when I would take off. It would only really do it on a incline and when the clutch wasn't slipped right. On level ground where taking off wasn't a hassle it never flashed. I haven't driven it since Sun, but I'm gonna check the oil level when I get home from work. If the oil level checks out fine I guess I'll be calling the dealer.
Oil level checked out to be fine. I guess I'll drive it some more and see what it does. It may have just been the way I was taking off cause I was in traffic in some mountains and wasn't working the clutch all that great.
I have had my oil tested and its fine. More than likely a sensor issue from heat. The heat is probably generated from the brakes as I could feel the heat radiating from a good distance away and the sensor is fairly close to the heat source.
mitsumaster
Nov 14, 2015 07:55 AM
StlEvo05
24
Mar 10, 2012 08:31 AM
EvoHead7
11
Mar 7, 2012 03:56 PM
omniprobe
14
Aug 21, 2010 03:48 PM
