big turbo input needed
Old Oct 15, 2008 | 11:47 AM
20gmr's Avatar
your also limited by the red.....once you do go T3 pretty much any turbo fits in there and is easily changed. Don't be the guy with a bunch of money in a stock setup. yes they do make power but once your done your done. Were as if I as a T3 guy gets bored I could slap a bigger turbo in without changing hardly anything
Old Oct 15, 2008 | 12:36 PM
Billy@EnglishRacing's Avatar
i 30 will do the trick and it will be alot more fun on the streets then a 35
Old Oct 15, 2008 | 01:52 PM
Ev0cRaZy's Avatar
Dont forget the most important thing on your build....
A GOOD TUNE.
Old Oct 15, 2008 | 02:08 PM
sprx19's Avatar
This is just my opinion, but a BR stage 3 head would be the best bang for the buck if you are looking to make a lot of power on pump gas. On pump gas its all about efficiency. Race gas is like a big band aid. On pump gas you can't cheat.
Old Oct 15, 2008 | 03:39 PM
mrdevo's Avatar
Intake, injectors, and fp red-say 2400 for this including install
Add 3-400 for a tune and you will have 450-500whp with the best powerband possible at 25-30psi
A bigger turbo can do this but I wouldn't go big like that and over 30psi unless I was planning to build the motor anyway, which falls out of your budget regardless.
