Bleeding The Coolant System
Old Oct 22, 2008 | 08:44 AM
MitsuJDM's Avatar
When you guys do coolant flushes, are you bleeding the system? Is there a specific bleeder anywhere, or just bleed it out the funnel on the radiator cap? I tried searching but didn't come up with any results.
Old Oct 22, 2008 | 03:35 PM
AznDragonV's Avatar
I THINK there is a little hose thing on the bottom of the radiator.
Old Oct 22, 2008 | 04:23 PM
boostedwrx's Avatar
Theres a plug in the block too, not just the radiator.
Old Oct 22, 2008 | 05:03 PM
MitsuJDM's Avatar
At work, I use a special funnel that attaches to the radiator cap that will automatically bleed the system, but some cars have a bleeder "nipple" type thing. I just wanted to see if there was one on the Evo or if I could just use the funnel.
Old Oct 22, 2008 | 05:16 PM
whitey4d's Avatar
We all have them at work too. They re called a spill free funnel and they are adapters for all makes. But no there isnt a bleeder valve on the thermostat housing or on the intake manifold like V6 GMs that have 2 "bleeders"
Try bleeding the air out of a 2ZZ Toyota engine after going a water pump. It takes longer then doing the pump. We also vacuum the system, it helps alot.
Old Oct 22, 2008 | 05:21 PM
MitsuJDM's Avatar
Yeah, I wasn't sure of the exact name, but I've used them. I guess I'll just use it with the right adaptors when I do my coolant flush in a few weeks.
Old Oct 22, 2008 | 05:31 PM
Sharkbite2000's Avatar
funny thing I didn't have to bleed mine when I did my radiator just left the coolant cap open for a bit and kept pouring in a little at a time till it was good and just let it run for awhile haven't had any problems.
Old Oct 22, 2008 | 05:38 PM
steelcityevo8's Avatar
+1
Old Oct 22, 2008 | 06:07 PM
whitey4d's Avatar
Unless you drain the block or are doing a water pump there isnt going to be much air in the system. All you supposed to do is run the car until the thermostat opens, top off, then the reservoir will fill the rest once the caps put on.
Old Oct 22, 2008 | 06:49 PM
barneyb's Avatar
Anybody actually have the block drain out when changing coolant? I found the thing but it looked to be a very difficult job.
Old Oct 22, 2008 | 06:57 PM
hanahawaiian's Avatar
no... I didnt use any fancy bleeding coolant.. i just pour water/antifreeze/Redline wetter water mixed till full and leave cap OUT... and running car and wait till all Bubbles are gone or fill more water in.. till bubble are gone and then put cap in...
it all good to go..
MR.EVO00
Jun 6, 2019 09:29 AM
chassis87
Dec 30, 2016 04:26 PM
coollol123
Lancer Aftermarket Forced Induction Tech
Jun 5, 2013 06:50 PM
OMEGA BLACK 79
20
Dec 18, 2009 07:54 PM
cognisa
Apr 25, 2004 11:20 AM
