rough idle on cold days?
500-700 it shook bad and felt like it was going to die...
throttle response was very bad..
If I was on the throttle, the turbo spooled to double the boost it would normally be at for that amount of rpms...
If I gave it too much throttle it would 'stall' like a fuel cut feeling and back fire.. that was at only 4000 rpms...
after driving it for 15 minutes it came out of it and drove normal..
only happened once and hasn't done it since..
Does the answer have to be repeated? Take your hks bov, grab a trash bag put it in the trash bag and light it on fire, take your OEM bov put it back as recirc, get a tune, problem solved you're welcome
coming from a guy that has a hks screen name?
what's so bad about them
My friend has one on his IX vented to atmosphere with no tune and its fine. Your issue may be an idle control valve. when it idles low, cover the bov vent with your hand feel for vacuum.
are you kidding me n00b, just because my name is hks doesn't mean I run a bov
once you don't run maf then you can talk, I swear I don't understand why some of you guys buy these things I can understand running higher psi but honestly I doubt you'd be running more than 24 psi on your supportng mods
ahem...
http://forums.nasioc.com/forums/show...hreadid=468038
(who wants to bet he asks what MAF is?)
once you don't run maf then you can talk, I swear I don't understand why some of you guys buy these things I can understand running higher psi but honestly I doubt you'd be running more than 24 psi on your supportng modsI'll admit to being a noob... I've been a LS person all the way till I wanted something four wheel drive..
The car already had the bov when i bought it... what do you guys prefer to use?
kaymin,
MAF stands for mass air flow... thank you
hahah sorry dude, I was just messin around, I was in a mean mood.
anyways, get a stock BPV back on there and upgrade to the IX one while you're at it.
oh, did you read the link I left you? some good info in there, that guy writes a TON of stuff about subarus and I find alot of it invaluable to most turbo cars.
Here's a link to Unabomber's entire manifesto
http://forums.nasioc.com/forums/showthread.php?t=533787
I'd like to say that I've read it all but I definately haven't. lol
no worries man.... I'd bash someone too that doesn't know **** about their car... thats why i'm tryin to find out as much as possible..
I heard a mr bov would be a better 'upgrade' is that true?
So I'm betting you're waiting on a notification so I'm gonna double post (oh noezzz mod's don't killl meeee! I'm only helping!)
but I guess they're the same thing
(I'm new to the whole evo thing too, I pick mine up tomorrow)
so yes, that's what you want
A tip, make the search button your best friend
no problem man, we were all new at one point. I just have an advantage that I've been obsessed with turbo AWD cars since I turned 16 almost four years ago.... wow seems like forever ago lol.
x7eVoLuTiOn7x
Nov 28, 2003 10:43 AM
