What mods would you do?
Old Sep 4, 2003 | 01:25 PM
Evo11V's Avatar
Veteran: Army
Question What mods would you do?
Ok,
Whats better?
Would you rather get the XEDE piggyback chip?
or
Get a boost controler, S-AFC and that kid on stuff?
Basically i'm confusted about the XEDE chip that recently came out. Can you boost your boost through the computer and at the same time it adjusts the air/fuel ratio? can someone help me... i did a search and i did not find anything answering a question like this.
Old Sep 4, 2003 | 02:41 PM
tom@kartboy's Avatar
some good reading here http://vishnutuning.com/xede_evo.htm
the
XEDE has been out for a while for the subarus. Shiv at vishnutuning has just recently made the avalable for the Mitsu's.
mine should be here soon
Tom
Old Sep 4, 2003 | 03:26 PM
freedom's Avatar
the
Tom
Are you running one on the WRX?
Old Sep 4, 2003 | 04:56 PM
No i ran a TEC-2 on my Subaru RST.
i've installed a few stage one kits on customer's WRX's. highly impressed with the results.
i have the Standard exhaust on my EVO right now and awaiting for the XEDE to arrive this week.
Tom
Old Sep 4, 2003 | 05:01 PM
Evo11V's Avatar
Veteran: Army
tell me what you think of it... how easy is it to change the boost PSI since i know it also has a boost control feature.
Old Sep 4, 2003 | 05:05 PM
freedom's Avatar
Download the tuning software from Vischnu. It is not clear how far you can get w/o a serial number. Realize that the cost is $100.
Old Sep 4, 2003 | 05:06 PM
Evo11V's Avatar
Veteran: Army
yeah i tryed that... soon as you go to enter the program it aborts with out the serial number... has anyone tryed it yet?
Old Sep 4, 2003 | 05:07 PM
N10S's Avatar
Does the XEDE actually control the boost or does it rely on an additional bleeder valve to up the boost?? I had heard the latter was the case, but this may not be right....anyone?
N10S
Old Sep 4, 2003 | 05:12 PM
freedom's Avatar
N10S
I should leave it to Vischnu to answer this but....
It takes over control of the stock control valve under the air box. I believe that it also monitors the ECU's control. There is two modes discussed on Vischnu's web site.
Old Sep 4, 2003 | 05:13 PM
freedom's Avatar
I really wish there was a trial mode such that one could check on the tunablity of the unit. My guess is that there is a serial number which has a time limit on it but do you request that from Chip Torque or Vischnu?
Old Sep 4, 2003 | 05:27 PM
freedom's Avatar
Actually there is a demo file on Chip Torque's Xede web site, but the file is corrupt. I sent mail to them asking for either a copy of the manual or a working demo file.
We will see if anyone cares to respond or if they only deal with distributors....
Old Sep 4, 2003 | 05:29 PM
EVO-Bill's Avatar
I went with the Greddy E-Manage and I'm pleased with it. Does all that I want it to do and it was cheap.
Old Sep 4, 2003 | 05:52 PM
N10S's Avatar
Ok....so the XEDE box modifies the output data that controls the factory boost controller (FBC) which is located under the air box?
Is this done through the regular signal lead connection coming from the ECU? Are there any extra parts that have to be installed
to work with the FBC?
Sorry for all of the questions, but I had heard that there was an additional valve other than the FBC required to increase boost.
If the XEDE is just modifying the ECU signal, then it should require no extra parts or pieces, unless of course the dynamic range of the FBC doesn't respond to the modified signal without some kind of physical add-on.
I know this info may sound almost like I am heckling you, but trust me I am not. I am just interested in knowing how it works!
Thanks!
N10S
Old Sep 4, 2003 | 06:27 PM
check out the install page he has for the XEDE EVO. there is a small restrictor pill in one of the lines underneath the airbox. that will have to be removed.
i believe you can alter the boost curve with the XEDE under the tuning maps.
Tom
Old Sep 4, 2003 | 06:52 PM
N10S's Avatar
Thanks for the detail Tom, I will check out the site info as well!
N10S
