waste gate pressure?
Old Nov 4, 2008 | 08:43 AM
foxmr's Avatar
i have an 05 mr and was wanting to know what the stock waste gate pressure is.
thanks josh
Old Nov 4, 2008 | 08:47 AM
OhsixIXBish's Avatar
14.... i believe?? someone correct me if im wrong?
Old Nov 4, 2008 | 08:53 AM
foxmr's Avatar
ok well that helps for now but if anyone else can let me know for sure.
thanks josh
Old Nov 4, 2008 | 08:55 AM
vvhiteix's Avatar
i think its a little more...
yeah i think its 14psi is when it open but i would like to have someone confirm this...is there a reason u wanna know?
Old Nov 4, 2008 | 01:55 PM
foxmr's Avatar
yea im tuning.... but thats what i meen when it opens that would be the"crack" pressure and thats the number im looking for.
thanks josh
Old Nov 4, 2008 | 02:33 PM
Evolessfornow's Avatar
I thought wastegate pressure was 10 psi.
Old Nov 4, 2008 | 07:29 PM
sparky's Avatar
Base wastegate pressure on the 16G Evo's is almost always right between 10-12 PSI. Usually 11 PSI, but it can vary a bit from car to car, or turbo to turbo.
You can determine what it is on your particular setup by setting the adjustable, threaded, actuator rod to where the opening in the turnbuckle end freely slides on and off of the pivoting arm and at the same time running a length of vacuum hose from the wastegate actuator nipple to the nipple on the compressor housing discharge tube, making sure to plug off the open hose ends which lead back to your BCS or boost controller.
Having said that, most Evo turbos come from the factory with a little bit of wastegate preload. That means that the wastegate actuator rod usually leaves the factory shortened by one or two turns.
So, usual factory preload is an additional 1 or two PSI on top of the base wastegate pressure. As a result, from the factory you may get base wastegate pressure plus an additional PSI or two of preloading.
Old Nov 6, 2008 | 08:11 AM
foxmr's Avatar
that pretty much answerd my question thanks.
2006GSR
May 7, 2016 06:20 AM
Llew
Nov 1, 2015 08:30 PM
Addictuned Evo
Jul 25, 2012 06:11 AM
rraulston
10
Jul 27, 2005 07:19 AM
raywong
May 4, 2004 07:53 PM
