Whiteline Rearbumpsteer kit and alignment
I recently installed Whiteline's rear bumpsteer kit per the included instructions. My issue is I can't get the rear toe back to zero, let alone a little bit in like I've read I should do. At least not without using the camber adjustment (going way negative, damn near 3*) to straighten the wheels out. I have stock bilsteins and Swift springs if it matters.
Anyone else have this problem and what did you do to correct it? Thanks.
I have the bumpsteer correction kit and have never have any problems getting whatever toe or camber I want - currently run 0 rear toe and -1.2 camber.
I'd take it to another alignment shop for a second opinion, or recheck the installation.
Alignment shops couldn't do it either. They ended up setting it to -3* camber to get 0 toe. That's why I'm looking at it myself, rechecking the install. I pulled one arm off, so far, and the bushing wasn't pointing down like it should have been. I pressed it out and back in. It looks like it'll fix it. I'll update after I get it back together.
FS[Northeast]: Complete New Whiteline Suspension Setup
OverBoostedEvo
Apr 9, 2015 01:14 PM
GTWORX.com
16
Jul 11, 2010 10:43 AM
biggie5252
11
Dec 5, 2008 06:54 PM
3V0
Feb 8, 2008 08:53 PM
