FP RED setups, recommendations, and advice
Old Aug 4, 2009 | 06:56 PM
  #271
tscompusa2's Avatar
Originally Posted by BLKCarbonEVO
You don't want to push the turnbuckle out more. You want to turn in down more, towards the wastegate itself. The turnbuckle should be a ***** to get on the flapper!
ya on evo setup shimming wouldnt do any good now that i see how the actuator is connected. what you did is the only solution for the evo setup
Old Aug 4, 2009 | 06:57 PM
  #272
tscompusa2's Avatar
You are correct. I only have the N1 exhaust though. My 3in exhaust line is a custom bent straight through 3in w/o a cat or resonator.
ah ok good.
  #273
BLKCarbonEVO's Avatar
Old Aug 4, 2009 | 10:46 PM
  #274
Wick3d3vo9's Avatar
I want to spike 31 and hold atleast 28 till 7k. I'll spike 30 and instantly it drops and drops to 25.4 to 25.8 and I lose so much power
Old Aug 4, 2009 | 10:59 PM
  #275
You might be able to do that. you have ecu controlled boost? If not you should invest into the AEM boost solenoid. Also it may be your tune or a boost leak that will make you lose boost up top.
Old Aug 4, 2009 | 11:04 PM
  #276
xRoguex's Avatar
mods in sig with 950's going in. =)
Old Aug 5, 2009 | 11:05 AM
  #277
Wick3d3vo9's Avatar
I have a HKS EBC, I don't think I have a leak but I might.
Old Aug 5, 2009 | 11:57 AM
  #278
filly's Avatar
Hi what power can i make with my setup?
Its daily drive.
2.4 4g64 engine
FP red 80mm
ETS 3.5 FMIC
Walbro 255l
Pipercams and pullis
Autronic ecu
AVC-R boostcontroler
Snowperformance Methkit mix 50/50 water
3" Exaust
Thanks
Old Aug 6, 2009 | 08:23 AM
  #279
550ish but run 100% meth. Don't cut yourself short
Old Aug 6, 2009 | 08:47 AM
  #280
filly's Avatar
its engine power 550?
I hope 400 ; 420 awhp.
But 100% meth its a daily car will it be ok?
Old Aug 6, 2009 | 12:44 PM
  #281
yahu's Avatar
^It should be fine - I just make sure to get the pump flowing when driven (don't let the meth sit, basically). I think of a meth setup kind of like a hot tub - the worst thing that you can do is *not* use it.
btw - you should easily clear 420 to the wheels, unless you are on some low reading mustang.
Old Aug 6, 2009 | 01:25 PM
  #282
filly's Avatar
Around here its superflow dyno.
And not so high hp but high tq now running 380 hp and 650tq.
Hope to get som nice power from the red with a good tune :-)
Thanks for the reply
Old Aug 6, 2009 | 02:24 PM
  #283
No 500-550 to the wheels is reasonable for a Red. Yes 100% meth is daily driven. remember you are only injecting meth over say 12lbs of boost. under that and normal throttle you are running normal gas like 93 or 92 whatever you may have in your area
Old Aug 6, 2009 | 02:25 PM
  #284
Yahu, don't lie jk... I'm at 420 on stock turbo. Red with the right combos can make way into the 500s
Old Aug 6, 2009 | 05:59 PM
  #285
Wick3d3vo9's Avatar
You guys are seeing 500 plus whp on a red?? I'm at like 380 or 390 with 100% meth. . Its is a low reading mustang dyno but damn yall are making way more.
