Leak at O2 housing and Downpipe
Old Nov 17, 2008 | 11:54 AM
BlackSE's Avatar
I'm not sure if its actually a leak but after I installed my Megan Downpipe last weekend I've been hearing a hissing sound towards the front of the car. I would like to know what is the best way to check for a leak at the downpipe and stock O2 housing. The way I installed it was just using the stock doughnut gasket on the O2 housing. I'm not sure if I damaged it while insalling the new one. Is it better to use the doughnut gasket itself, take off the doughnut and use the provided exhaust gasket, or use both to hold the best seal? Thanks-Eryk
Old Nov 17, 2008 | 01:24 PM
sparky's Avatar
You´ll have to verify that the stock donut is in good condition otherwise purchase a new one from the dealership. Loosen the DP/cat(or test pipe) bolts first. Then tighten the O2 housing to DP bolts. Lastly, retighten the DP/cat bolts.
You have to tighten the O2 hsg/DP bolts first while the DP/cat bolts are loose. This assures a tight flat parallel seal between the O2 housing flange and the DP flange faces.
Old Nov 17, 2008 | 06:36 PM
BlackSE's Avatar
is it a bad idea to use both gaskets? I heard if two are used then one usually fails
Old Nov 18, 2008 | 08:43 PM
BlackSE's Avatar
So i still don't know what to do. Should i get a new donut gasket? Should I take off the donut gasket and replace it with a regular exhaust gasket? What are you guys doing to keep the seal?
Old Nov 18, 2008 | 08:44 PM
importjake00's Avatar
Get a new donut gasket. It should solve your problem.
Evo47
Jun 23, 2016 10:39 AM
wowzers
Jul 4, 2014 10:58 PM
ChUt26
Feb 19, 2014 11:57 AM
EVIL_EV0
10
Jun 1, 2007 05:48 AM
kduncan01
Jul 15, 2006 12:38 PM
