Evo 9, 6 speed
Old Nov 24, 2008 | 12:10 PM
EvowagonIX's Avatar
Evo 9, 6 speed
how much power can it handle in stock form, the maximum power u can make before start breaking the tranny and stuff.
Old Nov 24, 2008 | 01:28 PM
SHIFTT IX MR's Avatar
Depends on how you drive it. I know people with well over 500whp, and some in 600+whp territory with not a single problem. Then, of course, you have the hand full of people who are in stock form, or simple bolt ons, and they will swear that the transmission is defective.
Honestly, the 6sp MR transmission is extremely smooth, and while not as robust as the 5speed, if you know what your doing, exercise due care, and are not intentionally abusive to the point of being a careless idiot, the tranny can probably hold no more 600-700whp in stock form. This includes stock fluid, and internals of the trans.
Also you have to look at how you drive the car 90% of time, the enviroment in which the car normally operates, and whether or not you contribute to any type of prevenative maitenance.
Keep in mind that the 6 speed is prone to failure from excessive heat. The 6sp hold less fluid then the 5sp. Some people have added make shift coolers, that I believe work well. You can always go the Shep route, as well.
Old Nov 24, 2008 | 01:33 PM
vikevo9's Avatar
+1, I agree.
Old Nov 24, 2008 | 01:35 PM
KidEvo's Avatar
Also you have to look at how you drive the car 90% of time, the environment in which the car normally operates, and whether or not you contribute to any type of preventive maintenance.
Coudln't have said it better myself.
Old Nov 24, 2008 | 05:57 PM
EvowagonIX's Avatar
ok well its the its the JDM GSR 6 speed box, as the car is a 2005 Evolution IX Wagon. Thanks for the info, i drive with car, so i guess it will last when i turn up the power!
Old Nov 24, 2008 | 06:34 PM
PeteyTurbo's Avatar
It's a heat issue only surfaces when in high load in gears 4th and up for extended periods of time..
Old Nov 24, 2008 | 08:24 PM
EvowagonIX's Avatar
ok then, thanks.
Old Nov 24, 2008 | 08:34 PM
WICKed'N'EVO's Avatar
It wont blow if you dont abuse it.
The 6 speed would hold 1000 hp power just fine if you dont race long hours at the track like a auto cross event. Drag race the 6spd at the 1/4 should hold just fine like the 5 spd until it can longer handle it too.
Old Dec 14, 2008 | 01:58 AM
hennessey01's Avatar
Im under the impression that the 6 speed will hold up just like the 5 speed unless you try to kill it, which brings me to a certain question in which im trying to find answers to.......Have you ever heard anyone swapping the 6 speed mr tranny into the evo 8 with a 5 speed? I was thinking about doing it...but it's just a thought....i don''t even know if it could be done. Still learning on my car
Old Dec 19, 2008 | 07:06 PM
EvowagonIX's Avatar
yea i think it can be done, maybe the diff ratio would have to be changed though, not really sure
Old Dec 19, 2008 | 08:11 PM
SRT-TO-EVO's Avatar
It probably can be done but it would be a PITA since your car is an 03. You'd need everything for the ACD, to work plus the front diff, plus the 6-speed. Then's there's all the necessary things to make the 6 speed swap. So it'd probably be a headache.
What?
Old Dec 19, 2008 | 09:18 PM
JohnBradley's Avatar
ACD is just the transfer case and you dont need that for the swap.
What you do need is the 6 speed, shifter base and shifter, cables, and reverse and VSS harness. There is an 03 in the NW that has a 6 speed...my old one
From what I have read the JDM/EDM 6 speed is not the same as the USDM so the rules may not apply. I have been told its a getrag and not an aisin but I am not sure. I will look up the part numbers in CAPS to check right now and repost later.
Old Dec 19, 2008 | 09:25 PM
same part numbers...I guess thats just a rumor after all
learytiemer
Nov 15, 2010 10:11 PM
mrfred
May 13, 2009 03:53 PM
The Senator
Mar 22, 2007 01:02 PM
striderx88
Jun 28, 2006 04:19 PM
smokin_oz03
Lancer Engine Tech
Jan 15, 2005 12:34 AM
