The official 6-speed failure thread
It seems like a fairly often occurrence when someone in the market for an VIII or IX makes a thread here asking about the 6-speed. You know, just how "bad" is it compared to the 5-speed? And invariably, that person will get lots of posts from people either telling him to stay away from the 6-speed like the plague and lots of posts from 6-speed owners telling him they love their cars. This happens every time.
It seems like a good idea to me to have a more scientific way of ascertaining just how problematic the 6-speed has been for the Evo community. Hence this thread.
If you have/had a 6-speed and it failed on you, please post in the following format:
- username
- VIII or IX MR
- Mileage when failure occurred
- Approximate wheel horsepower and wheel torque when failure occurred and what type of dyno (if stock/stockish, just say that)
- What failed (4th gear, for instance)
- Cause/circumstances of failure (road racing, drag racing, street, etc.)
- Did you take any special measures to prevent this failure? (Oil cooler, etc.)
If, on the other hand, you have/had a 6-speed and have had no (major) problems, please post in the following format:
- username - current mileage - approximate whp/wtq and type of dyno (or stock) - if you race, specify road/drag - oil cooler (only if it applies to you)
I will begin the list in the second post and update it as often as I can. Hopefully this will help shed some more light on the 6-speed's tendency (or lack thereof) to fail. If anyone has any ideas about how I could improve the list to make it more helpful, I'm all ears.
Mods, this might be a good sticky if I get the feedback I'm hoping I will. Maybe in the Engine / Turbo / Drivetrain forum if not General?
Thanks in advance for your contributions.
- username
- VIII or IX MR
List of 6-speed failures:
mcjonnyp
IX MR
43,000 miles
370 whp
Issue: Third and fourth gear grinds at idle car will get stuck in third and 4th wont go in
Cause/circumstances: Failure probably due to hotlapping. Car also did many drag passes with no-lift shifting and no cool-down time.
razorlab
VIII MR
32,000 miles
340 whp / 320 wtq (Mustang dyno)
Issue: 4th gear shredded teeth
Cause/circumstances: Track use (TRE said heat killed it)
MR DAN
IX MR
15,200 Miles
300 whp
Issue: Failed mainshaft bearing (the sound is like having a dog-box tranny).
Cause/circumstances: 11 track events with factory tranny fluid change prior to any event
List of 6-speed users with no major problems:
Blitz - 24,000 miles - 300 whp / 300 wtq (Dynojet) - occasional autocross and drag
kanyonkid - 36,000 miles - 320 whp - lots of road racing and occasional drag
EvoJoeIX - 22,000 miles - 370 whp (Mustang dyno)
olmoscd - 30,000 miles - 400 whp (Mustang dyno) - occasional drag
Meeh Lucky IX - 17,000 miles - 500 whp / 407 wtq (Mustang dyno) - drag car
jxs1984 - 52,000 miles - 320 whp / 320 wtq (Dynojet) - occasional drag
Silver06evo9mr - 61,000 miles - 325 whp / 331 wtq (Dynojet) - lots of drag
TouringBubble - 26,000 miles - 330 whp - lots of drag and autocross
WickedWhtMR - 55,000 miles - 330 whp / 300 wtq - lots of drag w/ no lift shifting - grinds but has not failed
pogo - 74,000 miles - 340 whp / 340 wtq - lots of drag and occasional road racing
spdrcr456 - 125,000 miles - 330 whp / 334 wtq (DynoJet) - occasional drag and autocross
rane - 34,000 miles 323 whp / 310 wtq (DynoJet) - occasional drag
chaotichoax - 20,800 miles - 352 whp / 341 wtq (Dynojet)
Erik@MIL.SPEC - 100,000 miles - 333 whp (Mustang dyno)
Kdash106 - 35,000 miles - 320 whp
vd - 25,000 miles
EvolvedMR - 10,600 miles - 330 whp (DynoJet) - lots of road racing
Clutchdc5 - 48,000 miles - won't go into any gear at a dead stop, hard to get into first, but smooth when rolling
Kuslowski - 30,000 miles - 320 whp - lots of autocross
timmiii - 43,000 miles - 300 whp / 290 wtq (DynoJet) - occasional road racing
berniEVO - 38,000 miles - notchy 2nd gear, 4th gear grinds on fast/redline shifts, and 5th gear lockout when shifting fast into 5th from the top of 4th.
HyaboostaIX - 46,000 miles - 310 whp - occasional drag
mcjonnyp
IX MR
43,000 miles
370 whp
razorlab
VIII MR
32,000 miles
MR DAN
IX MR
15,200 Miles
300 whp
vd - 25,000 miles
400WHP (MD), 30,050 miles, ACT clutch. A "few" drag passes and dyno sessions. No grinding or slipping, and shifts like a champ. Stock oil cooler, only mitsu fluids (changed 3 times).
Wes get in here!
Wes get in here!
43000 miles 370 whp
act hdss clutch
lots of drag passes
oem fluids only
third and fourth gear grinds
edit: failure probably due to hotlapping
act hdss clutch
lots of drag passes
oem fluids only
05 MR - approx 32k at time of failure - 340whp/320wtq on mustang dyno with track tune - 4th gear shredded teeth - track use (TRE said heat killed it)
There is a thread about this in the motorsports forum from 2 years ago with lots and lots of info.
https://www.evolutionm.net/forums/sh...221&highlight=
52k miles - 3 yrs ago, conservative tune, i made 301/295 @ 20psi on a dynojet... right now i would assume around 320/320 @ 23psi with buschur licp and o2 dump. this is my DD and i am on my 3rd clutch (two oem clutch crapped out. currently using ACT XT w/ street disc.) tranny fluid changed 3 times. stock oil cooler. have went to the drag strip maybe 4 or 5 times. replaced t-case @ 35k miles, 1 year later after doing donuts on dry pavement.
05 MR 330hp/300tq. Rebuilt at 30,000 miles. Previous owner abuse. About to be swapped for a 5 spd @ 55,000 miles. Trans grinds in 3rd and 4th. Bad synros... overly aggressive clutch+aggressive driving+no lift shifting+drag launching.
