FP Red Turbo
Old Dec 8, 2008 | 09:31 AM
ratsevoixmr's Avatar
FP Red Turbo
id like to get an FP Red. the question is what camshafts would be good contenders for that. I need a manifold, o2 housing. I got the injectors and everything else. id like to get some opinions about this help....lol.
Old Dec 8, 2008 | 09:32 AM
localtoys73's Avatar
interested in the same set up?
Old Dec 8, 2008 | 09:40 AM
well im hoping i get a lot of peoples opinion on this cuz im aiming to do this work by next year
Old Dec 8, 2008 | 09:48 AM
brodienuchies's Avatar
Lots of info here:
https://www.evolutionm.net/forums/sh...d.php?t=380134
It seems as though you need 880 injectors (min), upgraded FMIC, upgraded 02 housing, all fair amount of porting on you mani, possibly some porting on the RED Turbo itself, and some are running dump for even better performance.
That's really it. Obviously METH or race gas will give you more juice but not needed...
Old Dec 8, 2008 | 11:14 AM
scheides's Avatar
EvoM Moderator
I bet you could run it on the stock IX cams with decent results! Otherwise Kelfords or Cossies FTW.
Old Dec 8, 2008 | 11:55 AM
im getting the 880cc injectors and the thing is how much psi could you put down on a stock motor. ive heard different answer up and down the wall
Old Dec 8, 2008 | 12:29 PM
Shacochis06's Avatar
FP 4R's
Old Dec 8, 2008 | 12:34 PM
evo8fl's Avatar
you can see my sig or go here a full details https://www.evolutionm.net/forums/sh...d.php?t=383178
Old Dec 8, 2008 | 12:40 PM
skatermsmn's Avatar
Do you have e85 available around you, if so I would go that route, and as far as cams go, dont worry about those yet, theres a local guy around me that I think gained under 10 whp after he installed his cams on his 9.
Old Dec 8, 2008 | 12:43 PM
My bad, forgot to add cams. I think cams are a must. The RED is a high boost, higher RPM cam. It doesn't even hit full boost until 4200...therefore, having a cam that can breath lots of air at a higher RPM is key.
Old Dec 8, 2008 | 01:41 PM
why is everyone acting like 4200 rpm is laggy i know when i drive my car its hard for me to stay out of boost just like the stock turbo....full boost is anywhere between 4000-4200 rpm....
the red is not so much a higher boost turbo like everyone is complaing about...it does fine at 26psi and above...anybody buying any new turbo over stock and running less than 25psi is pointless anyway so people need to stop complaining and saying its a high boost turbo when they dont even have one
Old Dec 8, 2008 | 01:54 PM
evo_gerard's Avatar
i hope i'm not off topic. so in ur opinion if i'm planning on running pump gas alone all the time then i should go for a green instead(assuming that 26psi and above is to much for pump gas). what do u recommend as safe boost for a stock block pump gas engine and is the red a good turbo pump gas
Old Dec 8, 2008 | 02:20 PM
Mellon Racing's Avatar
I like the cosworth M2 on the IX, they've consistently made great power for my customers.
Old Dec 8, 2008 | 02:21 PM
Import Junky's Avatar
Preach on brother. I'm tired of hearing it. It's funny though, I think there's a guy running a 37r on 23psi......haha. Anyway I'm getting everything bolted on and tuned in a couple of weeks so you can check out my gains. I'll be running:
FP Red
JM Fab O2 Dump
FP4Rs
Ported/Coated Stock Mani
FIC950s
HFS-5
Obviously this is on top of all of my other boltons like exhaust, intercooler, intake, etc.....
Old Dec 8, 2008 | 02:22 PM
EvoDom's Avatar
im going with an FP Red and im ordering the cosworth M3 cams. look into them.....some sick power gains
