Is it normal if an injector looks different?
Old Dec 10, 2008 | 12:39 PM
DimitrisIX's Avatar
I bought a set of new PTE 880s and one of them looks different than the other 3 at the spraying end. It looks like it has a wider spraying design compared to the others. It is the left injector in this picture. The other 2 injectors look like the right one.
Precision told me they are flow matched but I was wondering if anyone else noticed the same with his/her injectors.
Old Dec 10, 2008 | 01:12 PM
ROAD RACE VR-4's Avatar
They look the same to me
Do they all have the same numbers printed on them?
Old Dec 10, 2008 | 01:32 PM
getsideways's Avatar
If you arent contricted by time id send it back or ask for the chart showing the flow cert.
Old Dec 10, 2008 | 01:51 PM
DimitrisIX's Avatar
Yes same numbers but there is a difference in the pitch circle diameter of the holes
Old Dec 10, 2008 | 01:58 PM
evane's Avatar
i'm not to sure on this but lets think here....If you have 2 buckets full of water and on the bottom you drill 6 holes with a pitch dia. of 6 inches and on the other one 6 holes with a pitch dia. of 3 inches, i'm sure that they will both take the same amount of time to drain as long as all the holes are the same dia.....so i'm sure it doesn't really matter with the flow but maybe the spray pattern of the injector....
Old Dec 10, 2008 | 02:02 PM
ModifiedMR's Avatar
If you bought them new call the distributor. Also you can call the manufacturer and ask them if that is how they should be. Another option would be to shoot AMS or Buchur etc. a pm and ask the pro's.
Old Dec 11, 2008 | 08:31 AM
siceclipse's Avatar
i cant see it...
Old Dec 11, 2008 | 03:38 PM
Dragracer187's Avatar
If you cant see a difference, please go see a eye doctor. I can clearly see a difference. They can be flowmatched, but I rather have the same spray pattern in each cilinder.
Old Dec 11, 2008 | 03:42 PM
EmeryatSTM's Avatar
There is no chance that I would use two different looking injectors. The spray pattern would be different from one to the other.
-Em
Old Dec 11, 2008 | 04:13 PM
HyaboostaIX's Avatar
I can see it...It may be alright, but before you go through the trouble of installing them and having to take them back out...send that pic to the people you got them from and ask them their opinion.
Old Dec 11, 2008 | 07:30 PM
bluemonster2's Avatar
i can see the difference. i never even thought to check my injectors.... got me feelin nervous.
Old Dec 11, 2008 | 09:09 PM
Positron's Avatar
good call. i will be sure to examine my new RC 1200 injectors before they go in.
Old Dec 15, 2008 | 08:09 PM
mrfred's Avatar
They should all be identical in appearance, especially at the tip.
