Air Filter Shootout Test - Results!
#152
Perrin: more power but not quite as good filtering abilities
Amsoil: slightly less power with better filtering capabilities
Both are superior to the Vibrant is every aspect though; no question about that.
One clear advantage the Amsoil has over the Perrin though is ease of cleaning. The Amsoil is cleaned with a vacuum or air compressor, where the Perrin is cleaned with a special cleaner spray and water, then has to be reoiled once dry (messy job).
#153
I was wondering if you could do the test over, and test each filter at varoius times of the day to see if this makes a difference. Also could you please test each filter at night, with and without a full moon? I would also like to see each filter tested with every possible intake pipe and each filter tested at various humidity levels. While your at it, please test each filter and intake pipe combination at various altitudes. That should do it for now!
Great test, thanks for taking the time to do it.
Dan (drb)
Dan (drb)
#154
Dan (drb)
Dan (drb)
Let's run the car under water to see how it compares to the James Bond Lotus.. LOL
Doc
#158
Dan (drb)
Dan (drb)
