Air Filter Shootout Test - Results!
#181
#184
Received my Perrin filter from MAP. I have good things to report:
The filter did come over drenched with oil. No problem, hot water, paper towel and an overnight sit on my floor vent with the heat on fixed that.
I was previously running the ETS intake with KN filter and having a HELL of a time tuning/maf scaling/injector scaling, etc. Basically, I was beginning to hate my evo every day with the constant stalling, richness, fuel mileage etc.
Installing the stock maf pipe with the KN helped tremendously but was still stalling at times. I attributed this to the KN not flowing very well on top of its closed/sealed top design choking the airflow/MAF.
Installation of the Perrin on the stock tube cleared EVERY pain in the *** problem I was having. For the first time in a long time, I was finally able to get my injectors scaled in perfectly and just got done tuning 20lbs for now as I had to un-do all the previous changesto fix/cover-up, etc the old intake set up.
I have happy as as pig rolling in mud that I can finally enjoy the Evo again.
Thank you MAP, Perrin, Scheides, s2kracka and the guys at the dyno for coming through for the Evo community!
-E
-E
#185
-E
-E
#188
here are some pics of the amsoil air filter installed with the vibrant maf adapter and stock maf pipe. no bolts come with the vibrant maf adapter, so youll have to go and get some from your local parts store. my camera sucks so you cant really tell the actual color of the filter, but it is really close to the blue of the greddy silicone couplers on my uicp.
#190
-E
-E
#191
I just got mine installed over the weekend coming from the stock airbox. I havent done the logging to check out the maf scaling but other then leaning the crap out of my tune there is absolutely no driveability issues. This is going from a blitz drop in filter to the perrin intake with the perrin/samco intake pipe.
-E
#193
Just an FYI on filtering capabilities...
S2Kracka cleaned his MAF the other day and found that it was like sludge coming out of there. That was from his Vibrant filter. We pulled my Apex'i filter and looked at my MAF this weekend and found it was almost perfectly clean.
#195
I picked up my perrin filter last night from MAP and was surprised to see that it was not too oily at all! I wrapped it in paper towels and dabbed and dabbed and dabbed, they stayed clean! There was a small oil film in the bag, but that was about it. I'll post pics of the new bishin setup all installed here soon.
I also took the opportunity to spray down my new MAF with about half-a-can of maf cleaner and then use a bit of super glue at the 4 corners of the honeycomb to help keep it in place. I have plans to upgrade the turbo, and don't want it bending/popping out!
