another boost leak question
Old Jan 23, 2009 | 06:19 PM
evokid511's Avatar
hi guys i made a post a couple weeks back about a boost leak i was having and thought it was my piping but it wasnt... if my boost is spiking 25 then dropping to 15 then cerrping back to 18, could that be my wastegate going bad possibly
Old Jan 23, 2009 | 07:03 PM
sparky's Avatar
What is your peak boost set at?
Old Jan 23, 2009 | 07:14 PM
evokid511's Avatar
25lbs
Old Jan 23, 2009 | 07:48 PM
sparky's Avatar
So boost climbs normally to 25#. Tapers down to 15#. Finally, boost creeps back up to 18#. Do I have it right?
Old Jan 23, 2009 | 07:52 PM
sparky's Avatar
In your modlist you cite a K&N intake. Would this be a K&N drop-in, a K&N cone, or the dreaded Typhoon?
Old Jan 23, 2009 | 07:59 PM
evokid511's Avatar
you haveit correct and i have a K&N cone on stock rubber piping
Old Jan 23, 2009 | 08:09 PM
sparky's Avatar
I would be curious to know if there is any preload whatsoever on your WG. And, if so, exactly how much. Could you do a run wth the MBC knob backed out to its softest setting to check, huh?
Old Jan 23, 2009 | 08:13 PM
evokid511's Avatar
idk anything about the wasteagte except it is stock... it was working fine about a week ago then just started doing it as i was driving home... and im not sure if i undestand what u mean... you want me to turn the boost controller all the way down to minimum boost and see if it still happens... i no they way i have it set now if i slowly go into boost it will hold 10lbs with no prob but as soon as i go above 10lbs is when it starts dropping
Old Jan 23, 2009 | 08:21 PM
sparky's Avatar
So, if I'm understanding what you say, you have turned the MBC knob all the way out to is minimum setting and you got 10 PSI?
Old Jan 23, 2009 | 08:23 PM
evokid511's Avatar
no sry bout that i was asking if thats what u wanted me to do... right now its set to 25lbs but if i climb into boost easy to 10lbs it doesnt creep down but as soon as i go any higher it starts creeping down and doing the same thing it does at high boost
Old Jan 23, 2009 | 08:28 PM
sparky's Avatar
Yeah, I'd like you to turn the MBC knob all the way out to its minimum boost setting and go out on the street and test it to see what boost reading you get that way(with the MBC turned all the way soft).
Old Jan 23, 2009 | 08:33 PM
evokid511's Avatar
ok give me a min and i will let you know
Old Jan 23, 2009 | 08:42 PM
bbyevo8u's Avatar
??? what does that do for him ???
Old Jan 23, 2009 | 08:46 PM
evokid511's Avatar
well witht he controller all the way down it would go to 15lbs and then creep its way up to 20lbs holdig that... that sounds weird to me
Old Jan 23, 2009 | 08:59 PM
sparky's Avatar
I think that we could dial in 4 PSI more of WG preload and it should solve the problem that you are experiencing. At least it's worth a shot. Do you feel capable of tinkering with the actuator rod yourself or not?
