Just Changed Clutch & Now Check Engine Light On
Hey guys,
Just changed my clutch yesterday and now i get a check engine light, i had the car for two years and check engine light never came on!
If anyone has any imput will be greatly appreciated.
Thanks
Thanks
just some random info....when i got my exedy twin hd installed i had a CEL for EGR had insufficent flow....go to autozone or o'rileys and have a clerk use a code reader to find out what code it is....or if you have a laptop and a tactrix cable download ScanTech and do it yourself
Is your airbag light on toooo? If so someone broke your clock spring when the clutch was changed. If you don't tie up the steering wheel and change the clutch by removing the k-member and the steering wheel will fall to one side. If it's not put back on by putting the steering wheel back to original then your wheel will look centered but the clock spring will be max'd. If you heard a slight pop after turning the wheel then that's what it is. They're like $180 last time I checked.
Hope it helps.
Hope it helps.
thanks for all the imput guys!
The SRS light is not on. I will go to my buddys shop to find out what code it comes up as?
any other imput it will be appreciated again.
Thanks
Thanks
spider72
Jun 30, 2010 08:00 AM
marinejensen
Feb 2, 2009 06:26 PM
