Fp Red Boost Creep PLEASE HELP!!!!!!
Old Feb 6, 2009 | 06:44 AM
mugen777's Avatar
Well long story short I ended up getting another fp red after I sold my last one. Luckily my buddy was trading his fp red evo in and I snagged it by trading some things with him .
Anyway I AM EXTREMELY FRUSTRATED at this point I have bent over backwards and can't figure out what the issue is.
I have been in touch with FP and we just haven't figure it out yet. By the way FP has been VERY VERY helpful and they have some awesome customer service and I will DEFF continue to do business with them
My boost will creep to 30+ no matter what I do. Here is what I have tried.
1. I have by passed my boost controller ( ran a line directly from the wastegate to the compressor pipe nipple)
2. I have changed my fp hp wastegate to a stock actuator.
3. I removed the hotside of the turbo and had it fully ported.
4. Set the preload of the wastegate to the min and max and everywhere in between.
5. I got a new gasket for my o2 housing my previous one was about burnt up.
6.I checked all clearences, replaced all vac lines, tried another boost gauge.
EDIT: I also tried re assembling my boost controller and oiled everything, but not like it matters because its still doing it when I bypass it as well.
I am really hating my car right now, someome please help me out!
Old Feb 6, 2009 | 06:51 AM
evane's Avatar
what happened when you put the stock wastegate on the FP RED?
Old Feb 6, 2009 | 06:53 AM
mugen777's Avatar
Originally Posted by evane
what happened when you the stock wastegate on the FP RED?
Still creeped to 30. It would spike around 12-18 and make its way up to 30+
Old Feb 6, 2009 | 06:54 AM
evane's Avatar
and you didn't have boost creep on your stock turbo w/ the stock wastegate?
Old Feb 6, 2009 | 06:55 AM
mugen777's Avatar
None at all, it would taper actually
Old Feb 6, 2009 | 06:58 AM
evane's Avatar
you should try taking the wastegate off and see what happens if you even boost with no wastegate that turbo is haunted!
Old Feb 6, 2009 | 07:00 AM
mugen777's Avatar
I actually do, I took the wastegate off of the pivot that connects to the flapper so it was closed all the way and all the exhaust gases were coming out of the o2 dump and it slowly creeped.
Old Feb 6, 2009 | 07:05 AM
evane's Avatar
what did your boost creep to with the wastegate off?
Old Feb 6, 2009 | 07:11 AM
555R's Avatar
external dump
EPM downpipe to the rescue
saw your mods
you have it already
did you port it at all
i know there is another post here regarding that same issue
i think it lead up to the
stock internal gate wasnt enough to control the red
Old Feb 6, 2009 | 07:12 AM
mugen777's Avatar
I was only in 2nd gear so it didn't hit full potential but around 25ish
mugen777's Avatar
Originally Posted by 555R
external dump
what???
Old Feb 6, 2009 | 07:17 AM
Mellon Racing's Avatar
tune it for 30psi
Old Feb 6, 2009 | 07:21 AM
evane's Avatar
if your hitting 25psi with the wastegate off theres a problem....with no wastegate on you shouldn't be able to boost at all maybe 1 or 2psi but thats it...
there has to be something wrong with the turbo...
you could put your FP HP wastegate on someone elses red and see if they boost creep but i doubt they will...
sounds like your problem is with the turbo but i dont know what that would be...
Old Feb 6, 2009 | 07:23 AM
evane's Avatar
Originally Posted by Mellon Tuning
tune it for 30psi
VERY GOOD SOLUTION!!!! Your always on top of things Mellon haha
Old Feb 6, 2009 | 07:24 AM
mugen777's Avatar
I am going to go hang the flapper all the way open and see what happens ill brb
