cosworth piston to valve clearance ?
Old Feb 22, 2009 | 07:28 PM
loosecannon's Avatar
cosworth head : piston to valve clearance ?
hi anyone , i rebuilding my motor with a cosworth head , anyone knows the mininum clearance between the intake/exhaust valve to piston ? thxz
Old Feb 22, 2009 | 08:44 PM
KevinD's Avatar
i know for a fact that if you ever have to machine 5 thousands off the bottom of the cosworth head (or the block for that matter), it wont clear stock pistons
Old Feb 23, 2009 | 07:09 AM
thxs for the heads up , i will be checking the clearance with clay putty in the piston before i fire it up . i just the clearance numbers to be sure , before it becomes a expensive mistake ....
Old Feb 23, 2009 | 10:31 AM
cosworthevo1133's Avatar
yep +1 for kevinD he is talking about my old cossie head
Old Feb 23, 2009 | 04:32 PM
i measured the cossie head volume it about 46.2 - 46.9 cc . i trying to figure out the right head gasket to get it to the 8.8/1 compression . if valve clearance is a issue i'l' just add a thicker gasket . but may i know what happened to yours? thx
sobo
Feb 8, 2014 08:03 AM
AcePitcher11
May 14, 2009 07:58 AM
konstantinosIX
33
Apr 23, 2009 06:05 PM
cosworthevo1133
12
Feb 11, 2009 10:31 AM
pengulns2001
Aug 10, 2006 06:17 PM
