28 pounds no meth!
Old Mar 11, 2009 | 08:11 PM
sulikfish18's Avatar
28 pounds no meth!
just got car back and made 450whp, thought it was on 24 or 25 pounds but drove around today and saw it was running 28 or 29.. took it to get dynoed on differnt dyno and only made 400 whp?? any ideas why and how bad it is to run that much boost without meth? thanks a lot
Old Mar 11, 2009 | 08:15 PM
sparky's Avatar
What kind of boost gauge? What octane gasoline? Stock IX turbo? Who did the tune? If it wasn't self-tune, then you may want to ask the tuner what he thinks about that boost level.
gpintoevo9's Avatar
450 to 400 whp could have been due to different dynos. If you still feel it the same, no need to worry bro. i hope its 28 pounds on higher than 91 sh*tang we have over here
Old Mar 11, 2009 | 08:31 PM
yea its 93 octane on an fp green
Old Mar 11, 2009 | 08:32 PM
and a defi boost gauge
Old Mar 11, 2009 | 08:36 PM
Q@EvoPowerMods's Avatar
Built/Stock Bottom End?
28/29 lbs spiking or ?
EBC/MBC?
Ambient Temps?
different dynos/correction factors weigh into the variance in power level.
Old Mar 11, 2009 | 08:39 PM
sparky's Avatar
26-27# with a Green on a Mivec, would be a safe limit, depending on the tune. I run 23 on 91 in my VIII which is Green equipped, and I've run 25.5# on 93. Why don't you log knock to make sure. I think that 28-29# is pretty high on 93. Did you test boost in 5th gear?
Old Mar 11, 2009 | 08:40 PM
ok nevermind the difference in the horsepower, im sure it was the dynos being different, but is it safe to run 28 pounds, manual boost controller, stock internals besides cams?
Old Mar 11, 2009 | 08:43 PM
TTP Engineering's Avatar
Why do people think that a "built bottom end" means you can defy the laws of physics and octane and automatically allow more boost or timing at the same compression ratio as a stock bottom end?
If I had a dollar for everytime I saw someone write, "it has a built bottom end, it should take it", I would be rich.
Old Mar 11, 2009 | 08:46 PM
I would think that oem rods are a tad bit weaker than something like Pauter, etc...I've spiked to 35lbs on my oem bottom end, but I don't want to do that again. High Boost wont kill rods but throw in some knock and Bam...hole in oil pan
Old Mar 11, 2009 | 08:58 PM
SWOLN's Avatar
Your Defi gauge is approximately 2 psi off, so 26 psi is about right.
Old Mar 11, 2009 | 08:59 PM
How do you know that its off??
Old Mar 11, 2009 | 09:01 PM
Rods are irrelavent on an EvoGreen.
The notion that you can detonate and preignite a "built motor" and not a stock motor is ridiculous. It pits pistons, smashes rod bearings and ruins engines, regardless of the build. You cannot force the laws of physics to make power over octane limitations and detonation thresholds.
Old Mar 11, 2009 | 09:02 PM
SWOLN's Avatar
Because most of them are including mine. Says so on 2 different dynos and my EVC 6.
Old Mar 11, 2009 | 09:04 PM
thats stupid i thought they were supposed to be top of the line.. thanks though
