ACD HELP please
Old Mar 11, 2009 | 11:11 PM
MitsuEvo05's Avatar
ACD HELP please
i just got my clutch done recently at some local shop. he changed the clutch in 2 days and now my ACD has all the lights on (tarmac, gravel, snow). im worried is it something really bad? what needs to be done?
i did search and i did not find it
Old Mar 12, 2009 | 12:30 AM
sonicnofadz's Avatar
Ask the shop monkeys what kind of fluid they put in your transfer case. Ask them if they bled the transfer case. Then ask them what fluid they used. Despite what the shop says, make sure you check to see if there is any fluid in your transfer case, and if there is, replace it with OEM fluid (or a synthetic equivalent) and be sure to bleed the system as well. Lesson learned, don't take your Evo to a shop who has no idea what an Evo is.
Old Mar 12, 2009 | 05:35 AM
JakeTheVIII's Avatar
I thought the 3 lights meant a dead ACD pump, I could be wrong.
Old Mar 12, 2009 | 10:49 PM
MitsuEvo05's Avatar
i thought the 3 lights meant dead ACD something but i forgot why. so it might not be that bad? okay im going back to the shop tomorrow and ask about the tcase
Old Mar 12, 2009 | 11:56 PM
DIDYSIS's Avatar
Also ask them if they bleed the ACD With ATF 3 fluid, Check to see if its full. If they are like what fluid well CRAP!!!! Come to me next time :-) LOL, sorry to hear it. Good luck.
Old Mar 13, 2009 | 05:15 AM
Check out this first post : https://www.evolutionm.net/forums/ev...e-removal.html
Old Mar 15, 2009 | 09:46 PM
MitsuEvo05's Avatar
OKAY! folks after doing a oil change on my car and asking about the clutch job they did i learned 3 things!
1. the shop said they have no idea what the ACD is and they did NOT flush or no fluid came out
2. oil filter wrenches from my local kragen's sucks!
3. the ATF SPIII is completely drained out, assuming it was that shop but they were just lying or something! what do i put in there?! sorry i know im a super noob but better to ask and learn then to fail later.
Old Mar 15, 2009 | 09:47 PM
PeteyTurbo's Avatar
They let the fluid out and did not bleed it.. Plain and simple
Old Mar 15, 2009 | 09:55 PM
TTP Engineering's Avatar
Air in your ACD lines, ACD not working properly.
This is why you have Evo Experts work on the Evo.
Old Mar 15, 2009 | 10:02 PM
MitsuEvo05's Avatar
okay so tomorrow i am going to take it to my real mechanic (the one i took it to was referred to me)
i should just let him know to bleed the ACD and what?
BuiltS13
18
May 23, 2016 08:04 AM
aferalo
Dec 15, 2015 12:49 PM
Jaeger19
Sep 29, 2011 09:23 PM
justastockevo
Jun 2, 2007 12:33 PM
TurboTimah
24
Apr 12, 2007 05:07 PM
