Low boost after shifts... help
Old Mar 14, 2009 | 07:08 PM
Silvermike's Avatar
Hey guys,
I'm currently starting to tune my new build. I'm still at wg pressure. What I've noticed is that if I boost in a gear, say 2nd, I hit my 11-12psi and hold it till 7k. however, If i boost from 1st, into 2nd, I only hold 7ish psi after the shift and this persists until maybe 6k where the boost then creeps up to the 11psi again.
I suspect the dv may be leaking? I have a greddy RS recirc. I tightened down the adjustment all the way, still no change. any other ideas?
Thanks.
Old Mar 14, 2009 | 07:20 PM
sparky's Avatar
Remove the DV and plug the empty orifices in the UICP, MAF hose, and the reference line from the IM. Try driving and shifting this way with the DV out of the loop. This test should immediately answer the question as to whether of not the DV is at fault. Or, alternately swap out the aftermarket BOV for a stock DV, strictly for comparison's sake.
Old Mar 14, 2009 | 07:39 PM
sparky's Avatar
Are you still on the stock turbo?
Old Mar 14, 2009 | 08:00 PM
sparky's Avatar
How are you controlling boost?
Old Mar 16, 2009 | 04:58 PM
Silvermike's Avatar
im running straight wg, no solenoids or controllers etc.
its a 9 turbo on a 6gsr
Old Mar 16, 2009 | 07:36 PM
cfdfireman1's Avatar
The diaphragm in that diverter valve is notorious for wearing out and developing a hole making it pretty much useless.
Old Mar 16, 2009 | 08:37 PM
sparky's Avatar
Maybe it's what the fireman says. Because 7# is way low! Base WG pressure is usually between 10-11#.
Old Mar 17, 2009 | 06:33 AM
And the diaphragm problem tends to be more intermittent, sometimes you get boost next run you don't.
Old Apr 19, 2009 | 03:05 PM
Domolution's Avatar
Ouch, fix that asap!!!! :x
