stupid brake/clutch fluid question
Old Mar 16, 2009 | 01:17 PM
rgar's Avatar
I'm putting in a ss clutch line and am obviously going to have to bleed/add some clutch fluid when done, do I have to get this from the mitsu dealer? or is it safe to mix another brand. If it's not safe to mix, what's the best way to drain the clutch/brake fluid since it's a shared resevoir?
I was originally just going to drain the clutch fluid and put in some penzoil dot4 I had picked up but that was before I realized it was a shared system and it's starting to look like much more of a chore to bleed both at the same time.
Old Mar 16, 2009 | 01:22 PM
PVD04's Avatar
Any DOT4 will be fine. If you plan to do any track days, you'll want to flush your brakes and clutch with a higher quality DOT4, but for daily driving any DOT4 will do.
Old Mar 16, 2009 | 01:24 PM
edardnaekim's Avatar
yep what he said.
Old Mar 16, 2009 | 01:25 PM
rgar's Avatar
Can I just top off whats in there already?
Thanks for the quick reply. Hoping to get my car back together when I get home.
Old Mar 16, 2009 | 04:46 PM
PVD04's Avatar
Yes, all DOT3 and DOT4 brake fluids can be mixed. Just make sure you fill it up past the MAX line. That's how high it has to be to fill the clutch side of the reservoir.
verticalspark
Lancer Tranny/Drivetrain Tech
Oct 30, 2015 12:20 PM
toovira
31
Sep 1, 2008 09:08 PM
CrackerJackToy
Feb 20, 2008 09:23 PM
mauisurf2003
Lancer Troubleshooting
Sep 23, 2007 03:14 AM
Blacksheepdj
20
May 25, 2005 10:46 AM
