Stock WGA problem
Old Mar 24, 2009 | 11:55 PM
aguita's Avatar
Stock WGA problem
Hello
I just got a Stock WGA installed and for some reason I cannot Boost more than 10 psi..Not even when my ebc is on high setting,or turned off..? any suggestions
Old Mar 25, 2009 | 04:18 AM
pls1968's Avatar
Same thing happened to me last year and it turns out that the wastegate flapper inside the 02 housing was stuck slightly open. You might want to start there. Good Luck..
Old Mar 25, 2009 | 05:41 AM
sparky's Avatar
Begin by running a length of 4mm vacuum hose from the nipple on the WGA to the nipple on the compressor discharge tube("J" tube). Remove the cotter pin that holds the actutator rod onto the wastegate's pivot arm. Rotate the turnbuckle end of the actuator rod inward, which effectively shortens its overall length, placing more spring pressure on the wastgetate's flapper valve. Start off by giving it three complete 360* rotations. Try this and report back.
Old Mar 25, 2009 | 10:27 AM
aguita's Avatar
how should the eyelid (turnbuckle) be set? showing no treads?Yesterday when I installed the WGA I had only to slide in the eyelid to the flapper and the flappler was open and not building boost after that I adjusted the eyelid and I was able to boost to 10 psi no more...
Old Mar 25, 2009 | 10:31 AM
KevinD's Avatar
how do you have your boost controller hooked up?
Old Mar 26, 2009 | 01:26 PM
aguita's Avatar
My shop did the install..I think is working fine bc it shows the boost that Im running, So It should be working fine..Or how do I check if is not hooked up well?
Evolution IVGSR
Jul 24, 2015 01:02 PM
Srt4...
10
Jun 26, 2012 09:23 AM
cij911
13
Mar 28, 2010 02:18 PM
bank277
Jul 24, 2008 04:02 PM
evo_rc
Nov 30, 2006 07:18 PM
