Walbro 255 low pressure good enough???
Old Apr 1, 2009 | 01:48 AM
andyo1980's Avatar
I recently bought an 05 evo and was wanting to do some mods to it. Nothing too crazy, just basic stuff to get it mid to low 12's, maybe high 11's. I checked the fuel pump in it and it already has a walbro 255, but it's not the high pressure one. Will it still be good enough for my goals with the car or should I get the high pressure one?
Old Apr 1, 2009 | 03:47 AM
jmelocik's Avatar
What part number do you have in there? What do you mean by the Low pressure one? I thought they made a 190lph and a 255lph both measurements of volume not pressure, the Fuel pressure regulator is what maintains the pressure.
Josh
Old Apr 1, 2009 | 04:23 AM
Ted B's Avatar
Some Walbros (e.g. 255lph) come in low and high pressure versions. The LP versions are for normally aspirated cars, and AFAIK, their flow capacity drops more rapidly as line pressure is elevated (i.e. as a result of turbo pressure). If one has a factory sized turbo and uses pump gasoline, he'll probably be ok. It's always better however to get the proper 'HP' pump.
Old Apr 1, 2009 | 07:57 AM
vroomevo's Avatar
how can you tell if you have low pressure or high pressure? i am not sure what i have...
Old Apr 1, 2009 | 08:01 AM
importdps's Avatar
If you have a part #GSS317 pump its a 255lph low pressure/standard. If you have the GSS342 like the one we have the special on, its part #GSS342.
Your installation kit/filter kit will be a 400-847.
Hope that helps.
Rick
Import DPS
mrfred
68
Jul 13, 2017 11:22 AM
mrfred
58
Jan 4, 2016 06:09 PM
Grip Master
32
Sep 18, 2015 01:09 PM
xmaciek82x
Mar 22, 2009 04:49 PM
dEdiYT11
Oct 14, 2006 11:10 PM
