BlowOff Valve: Have Recirc or Move MAF sensor
Old Apr 7, 2009 | 08:05 PM
huevosrancheros's Avatar
Originally Posted by SmikeEvo
Leave recirculated. The MAF is programed to be in its location. Moving it will disrupt the readings it will see - aka, car will run like crap.
leave it the way it was intended to run.
Old Apr 8, 2009 | 08:58 AM
Davethewave's Avatar
Recirculating the air will help with spool. You will lose response on a stock turbo by not recirculating.
This is an interesting subject though.
Of course there's always someone saying "why do this" and the answer is simple, any gearhead love the sounds his car makes, BOVs can sound cool when setup right
Old Apr 8, 2009 | 09:05 AM
Nez136's Avatar
Response time lost could be .0009 sec. If it was really an issue, drag/TA cars wouldn't use them.
Its not just to sound cool, I have a Tial and am running 35psi, you can hardly hear my valve. Basically before Tial came out with a recirc valve the tightest valves were always VTA due to design for maximum performance.
Old Apr 8, 2009 | 09:07 AM
Nez136's Avatar
To the OP, stick with a recirc valve unless you are running a standalone. TO switch to a blow through setup just for the BOV is just dumb and a waste of time and money (no offense)
Old Apr 8, 2009 | 03:51 PM
timskyline86's Avatar
Im definetly not installing a BOV just for the sound, trying to look for what will cause the opt performance when replacing the turbo. if i only cared bout sound id just stick a whistle on a recirced BOV at like 95% recirc and 5% released if that even possible if not pointless lol
Old Apr 8, 2009 | 03:53 PM
also thanks for the knowledge learned couple things. Been out of the game for good amount of time and havent kept up with everything coming out like i use to.
Old Apr 9, 2009 | 12:14 PM
thepoint4life23's Avatar
what do the race evos use like the br 8sec evo
Old Apr 9, 2009 | 03:12 PM
hybridshooter's Avatar
cars like the br race evo run stand alone engine managment, so it's not really an issue for them.This more catered towards daily driven and street cars running factory ecu's.
Old Apr 9, 2009 | 04:48 PM
AWD_Terror's Avatar
Why does everyone wanna run open atmosphere?
Not worth the headache IMO.
My Forge Motorsports RS sounds damn loud enuff being recircd. And I am a total ricer when it comes to my BOV . lol
Old Apr 9, 2009 | 07:27 PM
Mautofied.IS300's Avatar
I run the same DV. I think it is the best because you can adjust the spring rate on the fly. Was really able to fine to it so there is no stutter when I go WOT to like 25% throttle. You can also switch it around either way and it makes two different sounds. I switch every month or so to change things around a bit.
-Will
NJ_evoIXgsr
Mar 10, 2017 10:53 AM
Realistic
30
Jul 16, 2009 05:38 AM
EVOgirlIX_MR
Feb 22, 2009 01:41 AM
locox
Oct 5, 2008 05:46 PM
dubbleugly01
Oct 5, 2006 09:32 PM
