is there a single MAP sensor I can use for everything?
Old Apr 7, 2009 | 05:29 PM
shunderwunder's Avatar
I'm currently running a Maft-Pro SD setup with a GM 3 Bar MAP sensor, a Zeitronix with their MAP sensor for my boost gauge, & the stock MAP sensor. Does anyone know of a MAP sensor that I can use for all 3 or even to combine 2. I really want to clean things up a bit if I can.
Old Apr 7, 2009 | 08:31 PM
evo8426's Avatar
with the evo x map sensor you can put it in place of the stock sensor and you can log boost and do ecu boost control
Old Apr 7, 2009 | 08:56 PM
I'm using my Maft-Pro to control boost so that wont work for me. I still want to retain all 3 setups, I just want them all to use the same sensor. I'm not sure it's possible but it can't hurt to ask.
Old Apr 7, 2009 | 09:43 PM
CO_VR4's Avatar
As long as each of the instruments you want to use employs the same calibration for the sensor output, Zeitronix will tell you how to split the signal from the MAP sensor to the various instruments.
