Put in Mini Battery- Gettin Lower Boost
I always noticed boost slightly lower in the lower gears and higher in the higher gears.
And it sounds to me like you were at a little over 1.5 bars and now you're showing at 1.5 bars? Is that right? That's small enough of a change for weather conditions or even a very very minor twist in your MBC. If you crank up your MBC a little bit more does it go up at all?
You could've bumped the MBC (dunno where you have it installed) or a boost line while doing the battery kit install...
i just got my buschur battery from a member here and I was wondering if there was a diy? The battery was already installed in the tray when I got it. Any input from the OP is appreciated as well as anyone else. Thx
fit4130bmx
Feb 29, 2012 05:14 PM
black E
Aug 21, 2011 09:14 PM
