FP Red Boost Creep
Old Apr 12, 2009 | 07:58 AM
AcePitcher11's Avatar
FP Red Boost Creep
I have been having some trouble with boost creep since I installed my Red. I had an 02 dump on the car and it would spike 28psi and climb to 35psi or so. I swapped my Megan 02 housing back on and now the creep is not nearly as bad but its still creeping some. My mods in that area are
BR ported manifold
Ported FP Red
Megan 02 housing
Forge Wastegate Actuator
3inch turbo back with test pipe
Forge Boost Controller
I am going to try putting the stock actuator back on and see if that helps. Something weird I noticed to that might be a problem is when I boost leak tested the car my boost controller started making a funny sound when we got over 15psi. It sounded like someone blowing a balloon up then letting the air squeak back out so I'm not sure if that's a sign that its bad or not.
Here is a screenshot of my log. I accidently logged my boost in KPA instad of PSI but you get the point and can see that my boost climbs as my rpm climbs.
Old Apr 12, 2009 | 08:35 AM
sparky's Avatar
So, exactly how much is it still creeping since you've gone back to the Megan from the dump?
Old Apr 12, 2009 | 08:39 AM
EvolvedGTI's Avatar
Check your timing! Happened to this guy!
https://www.evolutionm.net/forums/ev...ease-help.html
Old Apr 12, 2009 | 09:12 AM
Ill post a screen shot of my boost from my AEM Logger here soon that will explain to you guys what's happening. I already read that thread and I'm pretty sure my case isn't as severe as his was.
Old Apr 12, 2009 | 09:24 AM
bboypuertoroc's Avatar
Veteran: Army
I had creep on my Red. Solved it by turning my boost up.
Old Apr 12, 2009 | 09:27 AM
xxNosTankxx's Avatar
what kind of o2 dump were you using?
Old Apr 12, 2009 | 11:36 AM
Screenshot added of boost creep. I just swapped the stock actuator back on so I am going to go log it again and see what happens.
Old Apr 12, 2009 | 11:45 AM
GRNCT9A's Avatar
turn your actuator up some to hold more boost and turn your boost controller down. I'm boosting 26psi with a green and taper down to 24psi by redline by doing that. After I get my meth tune, I'll be at 30psi and tapering down to 27-28psi by redline. We'll see what my car likes.
Old Apr 13, 2009 | 04:55 PM
tony gibson's Avatar
Are you on the stock bottom end? Just wondering as I have a red coming to me this week and I am still on the stock bottom end...just wondering on the success rate of running the red on the stock bottom end. Sorry this is off topic btw. What ended up being the fix for this.?
Old Apr 13, 2009 | 05:02 PM
Evoryder's Avatar
Boost controller will leak out of vent hole when boost leak testing. You're supposed to by pass it.
Sugguestions, service your mbc.. clean spring and ball, make sure the lines don't have any holes...i'd replace them if i were you.
Old Apr 13, 2009 | 05:39 PM
GRNCT9A's Avatar
I think i read somewhere where you had to port the hotside to eliminate boost creep. It was offered for an extra $95 from FP, they should make that standard.
Old Apr 13, 2009 | 05:44 PM
kanyonkid's Avatar
hmmm the 2 reds ive been in spiked then raised 2psi to redline.... the red doesnt want to stop apparantly!!!!
Old Apr 13, 2009 | 06:03 PM
Had that done to mine....I hope it helps. Not a bad price as that is a time consuming job even with the right toolage.
Old Apr 13, 2009 | 06:49 PM
red03evo's Avatar
Not to answer for him but I believe in another thread he posted that he has a BR Stage 3 2.0 shortblock or something but stock head.
**Edit, here' s the thread. https://www.evolutionm.net/forums/ev...tang-dyno.html
Old Apr 14, 2009 | 04:46 AM
Thanks man^^^I think I need to start saving to build this block lol!
