do i need a new alternator?
Old Apr 21, 2009 | 06:56 PM
bbyevo8u's Avatar
when i turn my head lights on my car feels like it wants to die, the rpms dip really low? does the car need a better ground?
what do you guys think
Old Apr 21, 2009 | 10:22 PM
bbyevo8u's Avatar
bump!
Old Apr 22, 2009 | 05:00 AM
JakeTheVIII's Avatar
When my alternator went out, the battery light came on along with the "brake" light. Eventually, the car would die while driving down the street.
I would check the battery. I know what you're talking about, like it takes a lot of power to run the headlights. Fully charge the battery, if it still does it try replacing it. Or get one of those voltage tester things they use at autozone with the needle, and track down where the weak charge is in the power system. Check fuses too.
Old Apr 22, 2009 | 12:25 PM
dancarroll0283's Avatar
with the car running use a multi-meter to check the voltage at the battery. If its lower than 13.0-13.5 than its your alternator. also check the fuse on the positive terminal at the battery because the 100 amp fuse there is for the alternator and they sometimes can blow out!
Old Apr 22, 2009 | 04:23 PM
bbyevo8u's Avatar
ok will do, thanks
Old Apr 22, 2009 | 04:37 PM
pjsevo8's Avatar
Where is the fuse exactly on the positive terminal? Is it the one that has the plastic cover on it?
PJ
Old Apr 22, 2009 | 04:40 PM
projectevo9's Avatar
PJ
yes thats it
Old Apr 27, 2009 | 06:02 AM
flipsideR's Avatar
If you don't mind me asking, what's the mileage on your car? My alternator just started crapping out and I 'm wondering when these alternators usually go out.
evoalan
Jun 14, 2010 02:11 PM
Solley
Apr 14, 2010 08:06 AM
justa4banger
West Region
19
Apr 7, 2010 11:18 AM
Shaun@AWDMotorsports
Dec 19, 2007 08:46 PM
MitsuEvoIIX
Sep 23, 2005 11:08 PM
