Need help!!!ACD probleme
Replace broken part, fill fluid (mitsubishi diamond ATF), bleed ACD via bleeder valve under tcase. You can run the pump manually (to bleed it) by turning the igniition key to on and holding gas pedal to the floor (do not start car). The pump will only run for a few seconds and then have a friend crack the bleeder and close. REPEAT many times - don't let the reservior run dry while your bleeding or you'll have to start over.
Probably already have the answer - but that solenoid is not available seperately. My old Evo was in an accident back in 05 and I had to buy the whole ACD pump unit (~$1700) - now you can find them used for ~$300 or so. As someone mentioned, don't drive car without the fluid / or at least disconnect the pump - otherwise you will burn it out.
Chris
Chris
Chris
Chris
Also can you give me a link where i can buy a used one???
thnx
tlcoll1
Feb 24, 2018 10:06 AM
FS[West]: 06 IX MR ACD pump
deylag
35
Aug 14, 2015 09:59 AM
TwistedEvo8
Apr 6, 2012 08:16 PM
migs647
Oct 4, 2008 01:29 PM
