Stock block/pump power?
Those numbers are flat out amazing! I hope you can figure out the misfire and make a bit more!
How much boost were you running?
Aaron,
Those numbers are really impressive! 92 octane at 30psi, that's some good tuning going on! This turbo is looking to be one of the most promising turbos available. Great Job!
Thanks,
Michael
Thanks,
Michael
This is 29.6psi peak on both runs. The 531 was more about some timing changes and the 537 was with a little more boost but it didnt quite do what I wanted. it was on target for just over 30.
TTP just tuned a stock block to 602whp. Here's the thread: https://www.evolutionm.net/forums/ev...gineering.html
Yes this was straight 92, no methanol & no racegas, on a stock block. The tune is knock free, the torque level is a safe limit, so the horsepower is just a bonus. It will last as long as any other knock free 400 ft lb stock block barring any severe malfunctions.
dipsetinallday
29
Aug 17, 2009 09:30 PM
