ACD pump relocation
ACD pump relocation
I was thinking of relocating the ACD pump into the space where the oil cooler is located. I would be installing an APS coldair intake in its place.
I consulted with a friend who is a mechanic. They said they aren't sure if it is a good idea since extending the lines MIGHT cause less of a fluid pressure.
Anyone care to shine some light on this?
You should be able to shorten the lines. For some reason the stock lines go from drivers side to passenger side (around the front of the engine bay), then wraps back to the fire wall, back into the trans tunnel, and then does a 180 in the tunnel and connects up to the short fitting which attaches to the TC.
If you re-locate to the other side of the car, you should be able to remove ~4-5 feet of tubing.
Dave
Dave
