Help with rattle. Not Throw out bearing
Old May 21, 2009 | 01:58 PM
mressler12's Avatar
I have done many searches and cant seem to find an answer. I get a rattle under my car when at idle or in gear, clutch in or out. I have checked underneath to see if i can find anything that rattles. That came up empty. Anyone think its possible that the cat could be making noise? It has a buschur exhaust. Any help would be appreciated.
Old May 21, 2009 | 03:16 PM
ev0lution9's Avatar
i have this too does it seem like its coming from the front passenger side? if so i was told its most likely your downpipe hitting but who knows
Old May 21, 2009 | 03:26 PM
max4rw's Avatar
if you have a spark plug fouler for a cel fix check that it could be rubbing against the car....it happened to me and this could very well be your problem
Old May 21, 2009 | 06:50 PM
mressler12's Avatar
mine does sound like its coming from the passenger side. It just started doing it. Id love to find out what it is if anybody has any ideas.
Old May 21, 2009 | 06:53 PM
Gary 805's Avatar
I had the same issue when i first got my evo.
On your driveshaft going into your transfercase there is a metal sleeve. It may have come loose.
I took a big flathead at the time and pryed/ripped it off. Just make sure this is the issue before you take my advice and start ripping pieces from your car.
I at the time and now dont need the sleeve on there.
Old May 21, 2009 | 07:25 PM
mressler12's Avatar
Thanks for the idea. I will check that out tomorrow. its just so hard to tell where its coming from underneath the car.
Old May 21, 2009 | 09:03 PM
SpooksEvo's Avatar
I just found a rattle similar to what you are describing. it was my intercooler hitting my crash bar. I checked everything and never thought this was the problem til I slammed my door shut and heard it one day. Bingo. Rattle gone
Old May 21, 2009 | 09:43 PM
GRNCT9A's Avatar
Yea, I got a rattle somewhere too. Most likely something hitting and not a major problem. happens every now and then.
Old May 22, 2009 | 06:32 AM
mressler12's Avatar
the biggest thing is that it is coming from underneath the car but i cant seem to figure out what it is.
Old May 22, 2009 | 06:36 AM
ev0lution9's Avatar
its definitely possible its your downpipe or your CEL fix if you have one because i have a rattle in my car only at low rpms going into first gear im also thinking its me CEL fix on my test pipe..jack it up and check things out underneath
Old May 23, 2009 | 06:56 AM
mressler12's Avatar
Turned out to be the cat. Shake it and it sounds like theres rocks inside of it.
meckert
Sep 9, 2016 09:53 PM
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
J8dailo
Dec 11, 2009 04:55 PM
Evo1001
Nov 27, 2008 12:35 PM
bscott
Jan 9, 2004 09:31 AM
