EVO IX MAS Bolts Stuck! HELP!!!
Uhh, not sure what you mean...a bolt busted? Are you asking where to find a replacement? Did you strip the threads? Take a cutting wheel or a dremmel and cut it off.
If you are talking about the brass colored ones and the plastic piece on the air box that stops if from spinning is busted, then just take some pliers to it to hold it down.
