removing silencer from greddy ti-c
alright fellas im sure im not the only one who has asked this question. i Jus got done installing the new exhaust but it seems like the silencer bolts are welded on the silencer. How can i remove those stupid bolts???? thx
The Canister tip (the titanium tip) is attached to the actual canister which is attached to the silencer. All you need is a hex key (allen key) to remove it. Once you remove the silencer, you will need to find your own support for the tip because the silencer holds the the tip in place.
I honestly thought the exhaust was way too loud, so I put the silencer back in. Be prepared to have a different feel to the car once you take the silencer off.
dam, is it really that loud?? well with the silencer it sounds good still but only when u punch it. those dam bolts are really welded on the inside of the canister. i will try to use the allen wrench in the morning. thx
I mob with the Comp TiC with no silencer...it's loud, but i like for the time being. if you call greddy, theyll send you some nuts but you're better off just going to the hardware store and picking them up.
No need to drill it out. I have the same exhaust and run it w/out the silencer. It's not too loud, and you'll definitely want it out if you care about the power loss. Just use an allen wrench to remove it. You'll need to get some some new nuts to hold it on since they welded the old ones onto the silencer.
