is it ok to use this fluid for my tranny?
i have an evo 8 with 5 speed tranny. it have 5th gear grind in high speed shift, i was told that synchromesh oil will help. can i use the pennzoil synchromesh or the amsoil syndromesh? how often do you have to change the oil if i use snydromesh instead of the regular synthetic tranny fluid?
you grinding syncros is either bad syncros or you need to give you clutch a little adjusment.
oil's are not mechanics in a bottle they will not fully cure those symthoms,
our AMSOIL fluid MTG GL4 has done very well for customers and it is an 100% sysnthetic fluid.
I have been using Pennzoil Syncomesh in my tranny for 100k now. To be honest I don't think it will do anything for your grind. But the fluid definitely works well in our trans
Change every 6-10k here
