Bypass stock fuel solenoid
Old Jun 16, 2009 | 09:18 AM
T88H's Avatar
Hello guys, Can I bypass the stock fuel solenoid conecting stock FPR diretly to intake manifold?? I?m having fuel issues and I dont now if bypassing it I will go more out of fuel than controlling the solenoid the fuel press.
Thanks so much in advance
Old Jun 16, 2009 | 10:18 AM
Creamo3's Avatar
Yes, just be sure to disable the periphery bit for it in the ECU to avoid a CEL.
Old Jun 16, 2009 | 10:53 AM
Evoryder's Avatar
fpr solenoid doesn't affect fuel just controls cold start up. I'd look at injectors and fuel pumps
Old Jun 16, 2009 | 10:57 AM
4kinboost's Avatar
FPR solenoid adds fuel on hot start-ups. If you leave the connector on but bypass the vacuum hoses you should be ok.
Old Jun 16, 2009 | 11:00 AM
T88H's Avatar
Thanks so much guys, I will leave the connector on and I bypass the vacuum line to check if the problem is the solenoid
Old Jun 24, 2009 | 09:48 AM
T88H's Avatar
Hello guys,well my problems with the fuel gone.The problem was the fuel pressure solenoid.I had a problem that going over 19psi the car was out of fuel,once was bypassed the solenoid,the problem gone and car runs ok like in past boosting perfectly at 22psi.My evo9 is a EURO-SPECS , Evorider and 4kinboost told me that FPS dont affect the fuel pressure controls,in my case it was affected alot,so we have to check if there are some differences in the ECU controls between US and EURO specs evos.
Thanks so much for your help
Old Jun 24, 2009 | 05:45 PM
Evoryder's Avatar
^ I hope you don't think I meant fuel pressure regulator, I was referring to the fuel pressure solenoid
In the picture above it shows both the solenoid and regulator, once you disable the solenoid it can actually be removed from the car, in the US.
Here's my car with it removed, and just the FPR in place.
Old Jun 24, 2009 | 08:04 PM
barneyb's Avatar
I doubt the Euro controls would be different because the fuel solenoid is not part of emission equipment.
Without looking it up in the manual I don't know what pressure the fuel pressure regulator on an Evo maintains. So, lets say, for the sake of this discussion, it maintains 40 psi. Now this is 40 psi above whatever the manifold pressure is. So if manifold pressure is 10 psi vacuum then fuel pressure is actually 30 psi.
What the solenoid does is vent the fuel pressure regulator to atmosphere and the regulator now does not see manifold pressure. So, with the 10 psi manifold vacuum you still get 40 psi from the fuel pressure regulator. The solenoid is triggered during hot start and is intended to clear out fuel vapor that may have accumulated in the line.
What I can't figure out is how this would cause fuel starvation unless the solenoid was always venting to the atmosphere. Then fuel pressure would not go up during boost.
Old Jun 25, 2009 | 04:15 AM
T88H's Avatar
Yah, maybe its venting all the time to atmosphere,for thatreason the pressure dont go up under boost.Checked fuel pressure now,and is ok.
The most important is that the problem gone,and the car runs perfect.
Old Jun 25, 2009 | 04:17 AM
T88H's Avatar
No sir, Im talking and thinking about fuel pressure solenoid like you
Old Jun 25, 2009 | 04:21 AM
EVILBLOODBROTHA's Avatar
Thanks this was helpful. I was just looking at doing this
Old Jun 25, 2009 | 09:59 AM
T88H's Avatar
All the way,just bought a Walbro 255 fuel pump,Agency power fuel rail and a Aeromotive FPR with braided lines to run safe forever with good fuel feeding.
Old Jun 25, 2009 | 11:58 AM
Kracka's Avatar
I removed my FPR solenoid with no ill-effects even during the winter. I have a Walbro 255HP and I disabled the emission bits with ECUFlash.
Old Jun 26, 2009 | 04:12 AM
T88H's Avatar
How Can I remove the ecu bits for remove completely the solenoid from the engine ?? I,m looking to remove the EGR too and I need to disable too
Thanks in advance
Old Jun 26, 2009 | 06:36 PM
Evoryder's Avatar
^ https://www.evolutionm.net/forums/ec...solenoids.html
Soda
Oct 3, 2015 04:50 PM
gt30revolXmr
Jan 13, 2013 08:10 PM
PineappleMonkey
Jul 20, 2009 01:20 PM
kf6ytc
Oct 17, 2006 08:51 PM
