Timing issues
Old Jul 6, 2009 | 09:00 PM
evo8john's Avatar
Timing issues
Just looked at a log i made a little closer and realized that from 3 to 6 k i am only around 3* of ignition timing with 0 KR and 6k to 7500 it goes up gradually to 11. is this normal? How much timing should I be running (we only have 91 oct here in nebraska). Mods are 3" TBE, MBC at 22 psi, HKS intake, and Megan exhaust manifold.
Thanks Guys
Old Jul 7, 2009 | 05:55 AM
crcain's Avatar
Thanks Guys
It's hard to say but 22 psi and 91 octane might only take 3 degrees at peak boost. But to have exactly 3 degrees for 3k rpm doesn't make sense. As rpm rises, you can feed back some ignition timing. How much depends on a lot of factors.
Old Jul 7, 2009 | 12:13 PM
Evo8luva's Avatar
Agreed with above^
3* at peak seems pretty normal, but not increasing gradually as rpm climbs/boost tapers isn't right. 11* at 7500 might be all the timing your 91 can take at 20-22psi (or whatever it ends up at the top) but it sitting at 3* from say 3500~ to 6000 is weird. It doesn't boost creap or spike up real bad in that area, does it?
I know my built motor, big cam, IX turbo doesn't like more then 12-13* at 7500 on c
93 and 21psi. But my timing map is real smooth from 1-2* at peak and ramps up to 13, the graph looks completly flat there too.
mines5
10
Mar 21, 2017 06:30 AM
blackbalts
Jun 28, 2016 09:17 AM
Guitarplyr
Dec 18, 2013 02:50 PM
MREvo2k6
For Sale - Part Outs
11
Aug 3, 2007 08:18 AM
Sentinal
Sep 11, 2004 12:43 AM
