Clutch failure , act MB7-XTG6
Old Jul 8, 2009 | 02:21 AM
kaansahbaz's Avatar
Thumbs down Clutch failure , act MB7-XTG6
the problem : act xtreme duty 6 puk clutch failed right there.
Not much pressure on the pedal and gears wont engage when the engine is running. It engages when cars engine is not running.. means : you can put the gear in 1st 2nd 3rd 4th 5th 5th R , but when the car is running it doesnt
if you try to put the gear in 1st and start the car , car dies just like releasing the clutch pedal when it is in a gear. so , i got almost half pressure on the pedal , it vibarets (shakes) when running and doesnt engage.
what can that be ?
TIA
Old Jul 8, 2009 | 05:33 AM
Toxin's Avatar
A bit more info related to the clutch would help?
When did you put it in?
New throw out bearing?
Did this problem show up all of a sudden or did it gradually get bad?
Sounds like TOB died on you.
Old Jul 8, 2009 | 05:36 AM
Evoryder's Avatar
bleeding clutch line, slave cylinder, TOB....start in that order.
Old Jul 8, 2009 | 06:39 AM
churbo's Avatar
Does the clutch still have some feel in it?
Old Jul 8, 2009 | 06:45 AM
FX11's Avatar
Originally Posted by evoryder
bleeding clutch line, slave cylinder, tob....start in that order.
+1
Old Jul 8, 2009 | 07:11 AM
Kracka's Avatar
From how you describe things it sounds like your clutch hydraulic system needs to be bled or has a leak in it.
Old Jul 8, 2009 | 07:23 AM
brandon1304's Avatar
sounds like what happened to me twice with this exact clutch... the disk is welded to the flywheel... good luck .. keep us posted
Old Jul 8, 2009 | 11:01 AM
kaansahbaz's Avatar
a shop in San Jose/CA EIP installed it less then 10K miles ago.
so what happened is , the day before this thing happened , i was down shifting 3rd 3K RPM to 2nd. then i heard a noise little bit , the next time i pressed the clutch pedal half way it was there. the day after i start the car and little bit launch like 5K for 2 seconds , and pressed the clutch. then no more gear engaging.
dont know about the throw out bearing , i didnt purchase anything besides clutch kit
Old Jul 8, 2009 | 04:39 PM
Evoryder's Avatar
^ your kit came with a new TOB right? Rule of thumb is to replace the TOB EVERYTIME you change your clutch
Old Jul 8, 2009 | 05:52 PM
kaansahbaz's Avatar
^^ im not sure gotta ask my shop
Old Jul 9, 2009 | 04:15 AM
mugen777's Avatar
x2
OP
Same thing happened to me after a hard launch on the street and the disk welded to the flywheel, just like Brandon posted... goodluck!
Old Jul 9, 2009 | 11:28 AM
kaansahbaz's Avatar
i talked to the shop he said the spring is off the disc
Old Jul 9, 2009 | 12:31 PM
ant_turbo's Avatar
I had the same issues with my mazda after some axle snaping,,,,,,,
Here's a pic why it wouldn't go in gear,,,,It would only go in gear when the car was off,,,,But when it was started no luck,,,,
what can that be ?
TIA
The_Police
Apr 6, 2016 07:05 PM
McSlides
Oct 17, 2014 09:44 PM
High_PSI
141
Jun 15, 2014 05:10 PM
silverevo05
Jan 11, 2014 12:31 PM
SLO-EVO
Nov 9, 2010 11:59 AM
