how to tq crank pulley?
Anyone quide me on how to tq the crank pulley?
Just did my 60k and cams and stuff. Got everything back together and in the car and the car down on ramps.
I tried to have someone keep the car in gear and on the brakes while I tq from underneath, but the pulley wants to move just enuff to be a PITA
any ideas on how to get the crank to lock so I can tq this thing?
whats the torque spec.
in my dsm when I ever had it off - i just made sure it was good and coated with locktite and then put it on with an airgun. Just dont try to BLOW the thing apart.. if you have put wheels on - and then torqued them - you know how much it takes to get to or close to 100 ft lbs.. so just plan a lil more for the 140 or what ever is required.
The evo is a complex machine that is very sensitive to vibration especially on the stock ECU, make sure you don't cut corners on anything under your hood.
Don't do this/\ If the transmission is off get a pry-bar and have someone hold the flywheel into place with it while you tourqe it down. If the transmission is on put the car into 2nd gear and have someone apply the brakes or the e-brake might work, and just tourqe it to spec.
Or ever worked on a DSM...
Cuz first -- if the trans is off for a simple timing belt job... you did something wrong.
Second - Holding the brake like you suggested will cause nothing but headache.
Third -- Ecu? vibration? -- Put down the crack pipe.
You have never build a motor.
Your funny!
I agree, an air wrench works best for this. An alternative is to make a tool that has two holes in it that match the holes in the sprocket and a cutout for the bolt and washer. I have one of these too, made back when I had a DSM.
i dont have air, but I got it last night. I guess when i told my one friend to put it in gear he was confused or something. cuz I had someone else over last night and said, oh lets try this again and went like cake.
You most likely got a very inaccurate reading on your torque... fyi.
I dont have air either. I have a badass electric impact that i use on cam bolts and crank bolts. Works like a charm -- and doesnt have the kohanoes to break anything.
han74j
Jul 3, 2009 11:23 AM
_EVOlved_
151
Nov 26, 2006 06:04 PM
tx evo
34
Nov 26, 2003 12:58 PM
