Whining noise after belts/cam install
well I pulled the covers yesterday and checked the tension and the tension seems a bit looser then before. I didnt touch anything though, so it prob stretched a litle from driving.
It still makes the noise though.
When rotating the crank by hand it makes a funny noise kinda too.
So Im thinking its just the attributes of a kevlar belt.
I dunno what else to think?
Any other suggestions?
Can I start it without the accessory belt on to see if its that belt maybe making the noise?
what is the proper way to test tension? Like I said it feels good to me, but I didnt measure deflection if that is what needs to be done
Its the orig oil pump I would presume, so 56k
I looked at the vfaq and if I test the gap between the tension arm with the .15" drill bit , will that be the best option to test the proper tension?
come to think of it, I think i held onto that 2 pronged tension tool with a decent amount of force when the tension bolt was tightened by my friend.
Could that be off and the belt slack still feel fine?
Did they ever identify the source of the sound? I have the same situation, after installing a Greddy timing belt. Really need to figure this out. :-(
Thanks,
J
Thanks,
J
On my DSM I found the b-belt loose at timing belt time. So, I decided to set the new b-belt a little tighter than what was recommended in the service manual. Afterwards, I had a whine for awhile. Both belts were OEM.
EvolutionIXMR06
Apr 12, 2014 11:19 AM
