FP red what supporting mods ?
Old Aug 13, 2009 | 10:33 AM
mantosride's Avatar
well i have come to the conclusion that I will be getting the FP Red however I am starting to wounder should I do head studs and new gaskets, as well as steel lines ? just seems like this would be some added insurance for the high boost levels I will be running.
Old Aug 13, 2009 | 10:37 AM
tim85851's Avatar
you need a lot more than just head studs...
injectors...fuel pump...full exhaust...
tim85851's Avatar
theres more than that too...just cant think of all the mods you need...
cams will help...
Old Aug 13, 2009 | 10:39 AM
mantosride's Avatar
Whops ya i have a AMS TBE, fuel pump, intake, boost controller, FMIC, LICP so not sure if i really need headstuds and gasket but i want to be safe as possible
Old Aug 13, 2009 | 10:54 AM
cij911's Avatar
No IMHO....There have been numerous threads about this. Knock related pressure spikes are far greater (and more detrimental) than the additional air flow of a Red. The stock head gasket is awesome. If you want to use a stock gasket and ARP bolts, just make sure you follow the proper torquing procedure.
Enjoy...
Old Aug 13, 2009 | 11:28 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Read the sig that is all my supporting mods. But before this get locked cause it's been done already I would suggest you PM members such as myself, vendors, and other user of the FP Red
Old Aug 13, 2009 | 11:39 AM
Clutchdc5's Avatar
I'd go with double pumper the new oil feed line from fp. Big ol injectors. Ported exhuast Manila. Fmic. Licp. Fuel rail . And e85 my friend made a little over 500whp
Old Aug 13, 2009 | 11:42 AM
detroit pistins's Avatar
check this out.
https://www.evolutionm.net/forums/en...ns-advice.html
Old Aug 13, 2009 | 12:07 PM
Gary@MellonRacing's Avatar
u can aklso go to dyno results and check out what people have made hp/tq and with what parts
pls1968
Jul 13, 2020 01:16 PM
IRISHEVOX
12
Jan 9, 2014 04:15 PM
DarthSuperShado
26
Jul 31, 2009 07:38 PM
dambikeracer
29
Jun 16, 2009 10:26 PM
