O2 questions..
O2 questions..
I just installed a new o2 housing, and now for some reason my boost gauge is reading boost up to 29 psi. I am a little worried about driving it now. Can anyone think of a reason why it would do this? Also, How much boost can the stock engine handle?
Thank you
You'll most likely have to research the archives with refererence to porting(enlarging) the merge hole on aftermarket, tubular O2 housings. The operation could be done by only removing the DP while the O2 housing is left mounted on the car, I think. Enlarge the merge hole to the diameter of a golf ball at least.
neonglh
Sep 16, 2011 08:47 AM
boony
21
Nov 24, 2006 01:54 PM
