O2 housing question
Old Sep 13, 2009 | 09:45 AM
19fred82's Avatar
O2 housing question
Hi, i want to put a 3'' TBE on my IX and i wondering if there is a big power difference between a 2.5'' and a 3'' O2 housing?
Old Sep 13, 2009 | 09:50 AM
High_PSI's Avatar
They do help. A couple of years ago David Buschur used a Cheapo Ebay unit and picked up 15WHP on his race car. Also Evo Power Mods makes a KILLER Piece, one I use, it is an Open Dump, lets all the exhaust gas right out of the car.
Look at this bad boy. I run this and it rules.
http://evopowermods.com/
Old Sep 15, 2009 | 07:59 AM
TTP Engineering's Avatar
You run what? A bad webpage?
Old Sep 15, 2009 | 08:09 AM
SOEuro's Avatar
hahahaha
Old Sep 15, 2009 | 08:53 AM
Kracka's Avatar
Can't beat the Megan/Buschur unit. The Buschur is basically just a coated Megan aka "good" eBay version. They fit well, are durable, and make power, plus they're not loud and obnoxious like these dumps that are all the rage right now.
Old Sep 15, 2009 | 08:56 AM
We have the Megan units for $99 here:
http://ttp-engineering.com/catalog/p...products_id=47
The coating is a waste of money.
Old Sep 15, 2009 | 09:03 AM
K1tt3n5's Avatar
Do you like getting in battles over bs?
Old Sep 15, 2009 | 09:04 AM
MR White's Avatar
Is it really worth upgrading the o2 housing? Is that 15 hp top end
Old Sep 15, 2009 | 09:18 AM
Aby@MIL.SPEC's Avatar
yes.
it's all about reducing backpressure on turbo cars. especially as close to the turbo as possible.
the invidia o2 housing has a larger i.d. feeding the dp than a megan style o2 housing. invidia = ~2.820" / megan style = ~2.460"
someone in san diego; on 91 octane, went from a megan style o2 to a invidia o2 & picked up 8 whp from 5k-7500.
Old Sep 15, 2009 | 09:19 AM
ChrisCarey's Avatar
Any O2 housing that utilizes a stock location downpipe has to neck down to 2.5" at the mating point. The only full 3" solution can be found here, however performance gains will likely be negligible on the stock turbocharger. Upgraded stock location turbochargers are a different story
Also, we offer the Megan Racing unit for just $109.99 shipped, and we guarantee the best pricing on this unit if you are somehow able to find it for less
Old Sep 15, 2009 | 09:26 AM
19fred82's Avatar
ok so if i have the stock turbo i dont need the 3'' housing?
i tought that it would be the best to put a 3'' housing to fit with my 3'' exhaust...
Old Sep 15, 2009 | 09:57 AM
CAD EVO's Avatar
I had basically all bolts ons including cams. I went ahead and put a. ebay 02 on and it gave the car even more grunt.
Def worth the $99.
Originally Posted by Aby@MIL.SPEC
yes.
The Invidia O2 housing design is flawed. The divider wall between the wastegate dump and the turbine outlet is just a flat wall of metal that increases turbulence and decreased efficiency.
We have dynotested the Megan O2 housing to be the leader in tubular O2 housings.
We have a special this week on them for $75.
Old Sep 15, 2009 | 10:32 AM
grahamab's Avatar
Can you please post a link or some more info to back up this claim?
Old Sep 15, 2009 | 10:46 AM
ChrisBond1's Avatar
How much shipped to 60645? But will it work for my 10.5 hotside?
