blown turbo
Old Sep 14, 2009 | 06:45 PM
nonojoe66's Avatar
blown turbo
I was wondering if anyone knows of a good place to get my stock turbo rebuilt.. and how much this should run. also has anyone here rebuilt their own turbo before?
a couple of days ago I noticed a high pitched whistle coming from the car under wot, Didnt think much of it and kept driving around until today when I started to notice a loud whirring type noise whenever I make boost. at first I thought maybe it was just a boost leak or somthing but now im starting to think the turbo is blown.
Old Sep 14, 2009 | 08:42 PM
sparky's Avatar
Remove the MAF pipe and then grab hold of the nut on the turbo's shaft with your fingers. Check for back and forth(axial) shaft play.
If it needs a rebuild then send it in to either, Forced Performance Turbocargers, in Texas, or else, Blouch Turbo Inc., in Pennsylvania.
Old Sep 14, 2009 | 08:49 PM
fixem2's Avatar
Not sure on the cost of a rebuild kit, but you could get an 05 Turbo, which has an upgraded hotside compared to the 03 for $200 or so.
Old Sep 14, 2009 | 08:50 PM
buchnerj's Avatar
^ +1 Shaft play in the turbo fan is probably the culprit in the whistling, but it is a good idea to take it apart and check. Does the whistling intensify based on the boost increase? I wouldn't wander too far from home with this just incase something seizes...
Old Sep 14, 2009 | 10:29 PM
nonojoe66's Avatar
I took the intake off already, it does have a little shaft play... not sure if its too much or not tho but yea its a whirring noise--deff turbo related, thought it was a boost leak at first till it got louder.
where can you find a stock 05 turbo for 200? id be kinda worried it would be in the same shape this ones in
Old Sep 15, 2009 | 04:47 AM
JakeTheVIII's Avatar
I would never get an evo 8 turbo rebuilt. They go on this forum for $150-200 shipped for the full turbo, hotside, wastegate actuator, etc. Evo 8 turbos are so cheap.
I sold my 05 evo 8 turbo for $200
Old Sep 15, 2009 | 04:49 AM
lords3t's Avatar
Just send it to CBRD for a BBK build
Old Sep 15, 2009 | 04:57 AM
fixem2's Avatar
You can not get an Evo 9 turbo for $200, but an 8 you can. You have an 03, that turbo had a 9.8cm2 hotside and the 05 had a 10.5cm2 hotside.
Can't send it to CBRD for a BBK, as that is an Evo 9 variant turbo.
Old Sep 15, 2009 | 06:37 AM
That's what I thought, the BBK is an evo 9 turbo upgrade. Not an evo 8 turbo.
Old Sep 15, 2009 | 07:04 AM
nonojoe66's Avatar
if i can find an evo 9 turbo for cheap enough im going to go that route... is there anything else besides a tune obviously that I need to change? o2 housing will bolt up? I found a little crack in my manifold too so im probably gonna replace it with another stock one
Old Sep 15, 2009 | 07:20 AM
GaBe511's Avatar
You will need a conversion kit to fit an IX turbo to an 8. They sell them on most turbo websites for like $150 or so. You can rebuild the turbo yourself if you are handy with tools and you can usually pick up a rebuld kit for under $100.
Old Sep 15, 2009 | 07:28 AM
tscompusa2's Avatar
for whats its worth ALL MHI turbos have up and down shaft play.... in and out is what is bad.
Old Sep 15, 2009 | 10:11 AM
nonojoe66's Avatar
ok one more question... I found a 05 turbo from a MR so it has the 10.5 hotside... or i think, so thats a direct bolt on?
Old Sep 15, 2009 | 11:47 AM
fixem2's Avatar
Yes the 2005 turbo is a direct on your 2003 and will give you a little more HP at the same time. No conversion kit needed.
Evo9_Dubai
Sep 20, 2018 08:29 AM
rip03tarmac
For Sale - Cars For Sale
Jun 14, 2017 02:03 AM
Aidanlee1
Jan 10, 2017 07:08 AM
MurphDurph
Lancer Aftermarket Forced Induction Tech
21
Dec 29, 2008 06:36 PM
bluefire7002
May 10, 2008 05:18 PM
