greddy e-01 19psi to redline setting, anyone?
hi, i just install the e-01 ebc but can't hold 19psi boost to redline, i had try and try with no luck, can u guys tell me what all ur setting is? i have it as set55, gain30, start boost17.2 but it doesn't hold, thanks in advance
hugo
gcityhugo@aol.com
hugo
gcityhugo@aol.com
What are you holding now? First set your gain down, its too high. Somewhere between 10 and 20. Also, set your E-01 to take over at .6psi instead of where you currently are set.
I have mine holding 19.5-20 to readline.
TAKE OVER SETTING: .5psi
GAIN: 20
Boost %: 58-60% depending on Air temp.
GAIN: 20
my is holding at 10psi on the display, but it feels like stock 19psi, i don't know why is showing 10psi, i am sure i can feel the diffent if is only boosting 10psi, the take over setting is the same as over take boost setting?
time ?
duty rate ?
auto/manual ?
set ?
gain ?
start boost ?
where do i go to set the e-01 to take over at .6psi?
and what do u have ur boost start at? Sorry if my question sounds dumb, but this is my first time using a boost controller, got to learn someday..haha, i am glad people here is so helpful, thanks in advance
time ?
duty rate ?
auto/manual ?
set ?
gain ?
start boost ?
These are my settings in psi:
Start - 15
Duty Rate 60 or so
Gain 0
this is all in manual mode
You can use the rpm offset to level out your boost curve. Just record a run then play back to make ajustments.
I have never had a problem with spiking.
Keep recording your runs until you get it the way you want it.
good luck
Start - 15
Duty Rate 60 or so
Gain 0
good luck
