Ways to hold boost at higher rpms
Old Oct 1, 2009 | 10:19 AM
neonglh's Avatar
So... I need help guys. I am running 28 psi, about to crank it up more, but it falls hard up top. After 7000 rpm, its down to 21 or lower, and keeps dropping. I saw a video recently of an auto 16g 2g eclipse running no ic, and just meth, and he held full boost to redline.
I currently have 5th place for the stock turbo, and I want to keep moving up on the list. My MPH is pretty much stuck at 122 - 123 mph right now at 28 psi. I run the stock ported exhaust manifold, stock turbo with a ported hot side, buschur piping, buschur race fmic, etc... Is it that my motor is just moving more air than the turbo can, or are there tricks that I can do here.
I am about ready to rip that turbo out and weld up the wastegate
--mark
Old Oct 1, 2009 | 10:23 AM
TeStUdO's Avatar
Check out the ECU Controlled Boost thread in the ECU Flash forum. With just a few dollars, you can hold boost longer.
Old Oct 1, 2009 | 10:25 AM
neonglh's Avatar
I don't run a stock ECU, nor would I switch away from an MBC. I am more looking for different WGA's, stronger springs, or other tricks to hold more.
Old Oct 1, 2009 | 10:27 AM
justa4banger's Avatar
the turbo just cant hold boost cause its small, so i guess live with it...
Old Oct 1, 2009 | 10:28 AM
mt057's Avatar
Do you still daily drive the car? I have heard of people welding the wastegate shut. That seems a bit extreme though.
Old Oct 1, 2009 | 10:29 AM
neonglh's Avatar
There are ways, I just mentioned a few. I am not going to live with it, I am going to find the best way to hold more boost, and then do that. I am trying to track down the owner of the 16g car, so I can ask him what he did.
At a certain point, the turbo can only flow so much, and the motor flows more, but I know I have more in it than now.
Old Oct 1, 2009 | 10:30 AM
neonglh's Avatar
I don't daily the car, but I did put about 2k miles on it this year. It would be very extreme, and I don't want to weld it, but if it comes down it to
ok when you hold more boost let us know...
Old Oct 1, 2009 | 10:33 AM
neonglh's Avatar
You got it bra
big block ix's Avatar
You can spike that motha to the moon
Old Oct 1, 2009 | 10:35 AM
TeStUdO's Avatar
With the stock turbo and AEM, and not willing to switch to even a EBC, you will need a very high pressure wastegate tightened as much as possible.
Old Oct 1, 2009 | 10:44 AM
brent_strong's Avatar
What would an EBC gain over a MBC when it comes to the maximum amount of boost you can run?
Old Oct 1, 2009 | 10:50 AM
TeStUdO's Avatar
The boost solenoid on alot of them is able to control boost better than a MBC. It's not that it is better at getting to a max boost, it's better at KEEPING it there.
Old Oct 1, 2009 | 10:53 AM
neonglh's Avatar
Has anyone used the Forge WGA with the 19 - 24 psi base pressure spring, and then cranked that up?
Sure, you have more adjustment, but it won't affect the max pressure or taper.
Boost taper is generally accepted as a wastegate problem. I think something like a Forge wastegate would be a much more sensible decision than an EBC.
It also could simply be that his engine is flowing more air than the turbo can provide, but I don't know enough about the VE of the engine or the flow characteristics of the turbo to make that call.
