Oil leak after timing belt install...
This past weekend I replaced my timing belt on my 03 EVO VIII w/ the Gates performance kit from mitsubishiparts.net. I replaced all parts that came with the kit, and followed the instructions on the "How to" thread that I found on here.
When I was done I fired her up and everything ran great, but when I got back from taking it around the block I noticed I was leaking oil. My first thought was the oil pan as the instructions told me to raise/lower the motor via jacking on the oil pan (which I didn't like the idea of). And yes I used a piece of wood on the pan. It looks like it's coming from the oil pan seal on the timing belt side right in front of the filter.
Since this weekend I have dropped the oil pan and re-sealed using ultra grey RTV, but it's still leaking... I'm starting to worry that it's more than the oil pan seal and maybe the main seal, balance shaft seal or oil pump seal. There are also the oil cooler return lines that run through there and attach above the filter which I am also suspecting now. It only leaks when the car is running and a few minutes after it's shut off.
All of the seals I mentioned above looked dry when I was in there doing the timing belt. Does the hydraulic tensioner flow engine oil through it? Any help would be very appreciated... This is my first post, but I have been on here for a while. I usually find the answer to my question, but in this case I didn't find anything quite like this.
How big is the leak? A few drops? Is it pooling? The tensioner doesn't have oil going through it, it's fully self contained. It doesn't sound like you've pin pointed the area of leak yet. Take off your upper timing belt cover and take it for a drive and get it at full boost (do this to increase the pressure and cause the oil to leak). Stop the car and check around the timing belt side of the car, the power steering lines, anything over there to see if any oil sprayed on any of it. Does your timing belt have oil on it at all? Hand crank it to check it out. I had a small leak and I found it by first checking the leak with the upper cover on, then took it off and noticed that there was oil on the power steering reservoir and also the power steering lines, ended up being a cam shaft seal that was crooked somehow. Try that and let us know if it helps pinpoint it!
It's a decent leak... leaves a puddle everywhere I stop, yet I get to work in the morning (25 mile drive) and the dip stick is only slightly down. When I'm laying under the area I can see the timing belt through a small crack in the lower cover, and it's still bright blue. Doesn't mean there's not some oil on it. I'll pull the upper cover tonight to make sure. I'll definitely be jumping under her asap tonight!! Thanks for the reply, I'll post what I find tonight.
Tighten up your timing belt tensioner bolts. When reading the how-to thread on here, be sure to read ALL of the pages on that thread. Very helpful information throughout that thread.
That's the kind of info I was looking for, and it's what I was worried about... Looks like I'll be ripping into her again It does almost look like the oil is seeping from inside the timing case, but it's so hard to tell. Hopefully I'll have some answers tonight. Thanks for all the good ideas!!!
if you have the service manual it says this on page 11B-11
>>B<< ENGINE SUPPORT BRACKET INSTALLATION
Coat the threads of the seal bolt A in the illustration with 3M
AAD Part number 8672 or equivalent before tightening.
Tightening torque: 49 ± 5 N⋅m (36 ± 3 ft-lb) "
possibly one of the bolts on the engine bracket touches an oil reservoir and this could be causing your leak.
for some reason i cant upload the picture from the fsm but this is the bolt that is supposed to be coated in rtv
hope this helps and let us know how you make out
Eldor_T. (Jun 19, 2022)
I didn't get into any of the seals so I don't think that would be it, but I'll definitely be checking them out. I did look at them during the timing install and they all looked dry though... I had the top cover off tonight so I can verify that the cam seals are good.
The particular bolt your arrow points to I didn't take out though... I did remove or replace the hydraulic tensioner, tensioner arm (the bolt the arm swivels on), water pump, idler & tensioner pulleys. I'm sure it's one of those bolts. Maybe I missed something in the instructions... I'll have to double check them.
You guys helped a lot to point me in the right direction, thanks!! Unfortunately I won't be able to dig into it until next week b/c it's supposed to rain the rest of the week and I'm going away this weekend. Wish my garage didn't have a hole in the roof!! I'll keep everybody posted on how it turns out. Thanks again!
It sounds like it's most likely the tensioner bolt which makes perfect sense since it's right above where the oil's coming out. Assuming it is one of those bolts it probably means my balance belt's getting hammered w/ oil? Does anybody that has had this problem know if that's true? If that is the case should I replace it or just clean it as best I can?
I've also been reading more since I've done the job about how the pin on the tensioner is supposed to slide in/out freely for the perfect tension... When i installed mine it pushed out a little bit, enough that I couldn't freely insert the pin again. How much does this matter? Should I try to re-do the tension so the pin slides freely when I'm in there?
